piston rod side clearence - B18C1
Old Sep 2, 2009 | 10:57 AM
jlfrnce's Avatar
Default piston rod side clearence - B18C1
i am rebuilding my motor, gsr crank and rods was replaced with new due to spinning my rod bearing, so got new bearings and rings also. now when i tighten the first rod, i cant spin crank anymore, so does any1 know where to find the side clearence for the rods? seems to be the rod caps are .005 wider than the rod journals are cut on the crank
Old Sep 2, 2009 | 01:30 PM
jlfrnce's Avatar
Default Re: piston rod side clearence - B18C1
found it, end play is 0.006-0.012 and service limit was 0.016
kloneoner
Dec 31, 2013 07:43 AM
viera
Feb 19, 2010 12:09 PM
eg4life1202
11
Jan 14, 2007 09:17 AM
93slmdcvcsi
Mar 8, 2005 05:53 AM
hatchedzex
Oct 4, 2004 11:40 AM
