Paid a shop $350 for Rear Main seal.. 2 weeks later..
Okay so I have a 1998 cx with a d16y7. There was a oil leak coming from either the oil pan or the rear main seal.
I just did the oil pan gasket, and I paid a shop 350 to do the rear main Seal. So I'm not sure what they did, they seem like a shop that does good work..
What kind of trips me out is that it tooks 2 weeks for a leak to appear again, would a improperly installed seal take 2 weeks to start leaking?
and I don't know what factors can cause rear main seal to leak again, except worn main bearings, but someone told me you would hear a noise if your main bearings are worn.??
do you think the shop installed it wrong? should I explain to them how people do it on H-T (flip the old rear main seal inside out and use it to gently tap it in the new one with a hammer?) or will i sound dumb? should I tell them to use rtv on the outside edges of the rear main seal? since the service manual doesn't tell you to.. I'm just really scared/frustrated that the rear main seal is going to leak again after 2 weeks.
I'm going back to the shop tommorow. any help/suggestions feedback tips would be great
thanks for reading.
thanks for reading.
when they put it on they prolly had the spring come off the seal and just bolted it on.
^people do this and not realize the spring is off(causes leak) tell them to fix it or start tossing bricks
the round spring that is inside the seal. its easy for it to pop out when trying to get that over the end of the crank. on the inside seem of the rubber part, it sqeezes the rubber tightly over the end of the crank for a good seal.
heres a diagram is the red square (the actual rear main seal) where the spring is?
im on a gov cpu, i cant see pics. but the rubber ring is kinda folded the small diameter spring is inside of that, il try to find a pic for you
I just hope that it is them installing it wrong, and not their seals that are causing the leak im almost sure they aren't using a Honda rear main seal..
I wonder how I should tell them install the seal, I mean it really isn't rocket science, but at the same time I heard its only 1/10" between correct and failure..
thanks alot for the feedback.
only about 72,000 on the d16y7 but oil wasn't changed every 3,000 previous owner said he changed it around 5,000-6,000
Okay So I took my car to the shop and they are going to take it apart inspect it. I told him about how if 1/10" of the seal is off it can cause a leak. He said the mechanic is very very good, and can almost gurantee he didn't do it wrong.
He thinks its transmission fluid thats leaking, and said I might have to get a new transmission.
?? I don't get it, when I checked whats leaking it looks black (from oil mixing with the dust from the flywheel housing) and yellowish, kind of like oil, but I'm not too sure.
I hope hes not bullshitting me.
new trans? input shaft seal..
theres a little spring inside the seal that pushes outward to help it seal. same thing with output shaft seals on the trans...
The problem has been that the OP has completely dismissed the possibility that the oil leak could be coming from anywhere except the rear main seal that was just replaced. While the new main seal could be leaking, it's important to be open minded about the possibilities.
I'm thinking my main bearings might be worn.. but I do not know how to tell..
Here is what a guy said to make me think this.
QUOTE=JCCLARK;2741785]Rear main seals start leaking because the main bearings (crankshaft) wear and the
crank wobbles. It's only a small fraction of an inch, but that's the problem.
If you don't replace your main bearings, then any new seal you install
won't last long. Believe me, I learned this the hard way after changing one
several times. Once I changed the main bearings, it finally lasted.
Any "good" mechanic knows this.[/QUOTE]
I don't know how valid it is??
Cool Cool Island Breezes. BOY-EE
hmmm I think my main seal may be leaking as well. I really don't want to do the work myself as I have no time. I just put a clutch in and I was stupid enough to neglect installing a rear main seal.
Keep us posted, OP.
Keep us posted, OP.
Okay So When I brought my car in again, telling them theres a leak again They told me its the oil pan that was leaking again. and said they fixed it.
Everything was fine, 2 weeks later I see a tiny drop again!?! in the same exact spot!
WHY am I CURSED with this LEAK?? WHY? I just hope its the oil pan again.
I'm going to bring it back when its leaking a little more, so they won't try to tell me its not leaking.
