H22 Blue AEM Fuel rail
I got a used AEM Fuel rail works fine. Looking to get 90shipped.
AEM High Volume fuel rails feature a 1/2-inch fuel bore to support fuel flow for applications up to 1,000 horsepower. This large bore also dampens backpressure pulses created by larger injectors and works perfectly with stock injector sizes. An additional 1/8th NPT port is included to accommodate a nitrous set up or fuel pressure gauge. A custom fuel line fitting is included for the factory fuel line, and the ends of each rail are pre tapped to accept -6 AN or 9/16”x18 fittings for users who want to use custom fuel lines.
No additional parts required for installation
Specifically engineered for each application
Manufactured and assembled in the USA
O.E. fuel pressure regulator or AEM adjustable fuel pressure regulator mounts directly to rail with no modifications
