Honda S2000 Honda S2000
Clutch Question (Slave Cylinder)
Old Sep 2, 2009 | 08:32 AM
TypeR324's Avatar
Default Clutch Question (Slave Cylinder)
I have been having some slight issues with my clutch recently and I think it might be the slave cylidner. When I depress the clutch compltely it almost feels sticky or maybe a little crunchy when I start to release the clutch after being fully depressed. I had something similar happen when I first got the car 3 years ago and it was the slave cylinder. Could it be the master? Also does anyone know if there is a way I can visually inspect both the slave and master? Thanks.
Old Sep 2, 2009 | 08:55 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Clutch Question (Slave Cylinder)
Sounds kinda like the through out bearing to me. Any sounds associated with this?
Old Sep 2, 2009 | 09:18 AM
TypeR324's Avatar
There is no sound when I depress the clutch however when I get off the throtle while the car is moving the clutch makes a somewhat loud humm sort of sound. When I either depress the clutch or get back on the gas it goes away. I think thats just clutch buzz although it did get much worse when I had my clutch replaced with an aftermarket ACT clutch.
Old Sep 8, 2009 | 05:47 AM
i my honda
Global Mod
Did you install the clutch yourself or did a shop do it? The sound you are describing above does sound like clutch buzz.
Old Sep 8, 2009 | 08:42 AM
TypeR324's Avatar
I had a shop install the clutch. Any idea of how you can inspect the slave or master cylinder.
komat
Aug 6, 2010 12:04 PM
Wazup
Aug 16, 2005 09:22 AM
Paste
Aug 15, 2002 08:49 PM
