T-belt change questions........
i'm bout to change out my t-belt here...i have a few Q's
when i line up the crank shaft pulley there is 2 sets of marks. there is a set of 3 gauges on the pulley and just up ahead on the metal is another gauge and its only a single gauge ......which one is for TDC???
also..when i'm taking off the crank shaft pulley bolt, how do i MAKE SURE that the pulley does not move from TDC while i'm taking it off?
any tips and tricks???
please help. and thank you all
for d-series...!!!
https://honda-tech.com/forums/showth...ng+timing+belt
sweet thank you.
still dont answer my second question though..
but i'm guessing......the key thats in the crank pulley, is it a guide for the crank pulley to put onto? so that would mean once i have the crank pulley TDC, it'll be easy to make out and place the crank pulley back into place.......am i right?
yes. when you pull the belt off everything stays still. it doesn't go spinning in opposite directions like a bat out of hell causing time to stand still and clocks to melt... lol
sweet thank you.
