replaced transaxle seal 3 times and it still leaks
Old Sep 1, 2009 | 05:51 PM
jlow125's Avatar
Default replaced transaxle seal 3 times and it still leaks
I have had my transaxle seal on the passenger side replaced three times and it still leaks. All three times were by certified mechanics and the last time was at honda. Please help, this is frustrating the crap out of me. Thanks very much
Old Sep 1, 2009 | 06:53 PM
twentyhurtz's Avatar
Default Re: replaced transaxle seal 3 times and it still leaks
the surface is possibly scratched and damaged from the first time it was removed, causing it to leak from then on..
Old Sep 3, 2009 | 03:39 PM
jlow125's Avatar
bump!
Old Sep 3, 2009 | 04:04 PM
gritsak's Avatar
OEM or reman axle on the side it's leaking?
Old May 5, 2010 | 07:56 PM
jlow125's Avatar
remanufactured
Old May 5, 2010 | 08:01 PM
johnsc2235's Avatar
You might have a differential going out, very common if you have a axle leak and the axle seal does not fix it. The differential is getting worn so it moves more than it should and then the axle also moves more causing the fluid to come out of the seal...Sorry to tell you but I do believe that the diff is going out. I am a certified Honda tech and have been for over 11 years now.
Old May 6, 2010 | 01:54 PM
770_dc2's Avatar
^^^wat he said same thing happend to me replaced my axle seal and it was still leaking later to find out it was my axle that was bad
91b18a1ls
Dec 31, 2012 03:43 PM
TEGMAN89
Jan 11, 2011 05:12 AM
inh
May 21, 2008 04:30 PM
97grnrs
Jun 10, 2006 09:29 PM
