Crx Laggs/pause's around 3k to 4k when near Empty, Fuel pump? Injectors??
Old Sep 1, 2009 | 04:26 PM
88SeeOurEx's Avatar
Icon6 Crx Laggs/pause's around 3k to 4k when near Empty, Fuel pump? Injectors??
Alright guy's i have this issue and its getting annoying.
Car info:
88 crx with a jdm gsr
obd0 b16 injectors
obd0 b16 dizzy
obd0 b16 ecu
Problem:
from what i can remember, Only when i'm getting a near empty gas tank (at or a little above the line before "E", i'll be driving and my car will be fine but when i get to 3k or a little less, my car/motor will lagg/pause, then go normal, then lagg/pause then normal so i'm jerking really hard. It gets back to a "normal" drive around 4k.
could it be a bad fuel pump or fuel injectors? i have no idea what the issue could be.
thanks in advace
Old Sep 1, 2009 | 05:25 PM
johnnyonth3spot's Avatar
Default Re: Crx Laggs/pause's around 3k to 4k when near Empty, Fuel pump? Injectors??
mabey trash in your tank? try draining it then flush it.
Old Sep 1, 2009 | 05:28 PM
project91crxsi's Avatar
if you get on the gas really slow and smooth and stay on it through the gear does it do it? im having a similar problem
Old Sep 10, 2009 | 11:50 AM
88SeeOurEx's Avatar
Yea, and when i try and get on the gas to see if it'll be different i think i does it still but it kinda fights through it but not really.
88SeeOurEx's Avatar
good idea thanks. what would i flush it with?
Old Sep 10, 2009 | 05:36 PM
i found that mine had **** in the tank so i drained it, and loooked in it and it got all the dirt/badgas/metal shavings out, and am running fuel system cleaner, and its still doing the same thing, but i guess its worth a try
bradennicely
20
May 13, 2010 04:23 PM
grkblood13
Aug 26, 2008 04:49 PM
bman2033
14
Jun 12, 2006 07:00 AM
JLHDOHC
Feb 28, 2005 03:05 PM
kur0ryu
May 2, 2004 07:28 AM
