shock sensor wiring
Old Sep 1, 2009 | 04:12 PM
Mikal92's Avatar
Default shock sensor wiring
I got a shock sensor from my friend and I don't know what the wires go to. It has a red black, blue and gray. It also says mas on the front if that is any help
Old Sep 1, 2009 | 07:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: shock sensor wiring
My guess is it is a dual stage sensor, red and black will be power and ground the other 2 leads will be the first and second stage outputs, which is which I do not know but easy enough to find out with a meter.
What alarm are you connecting it to?94
Old Sep 1, 2009 | 07:08 PM
Mikal92's Avatar
Its a crime stopper but I'm adding it so I will have two shock sensors could I just splice it with the original one.
Old Sep 2, 2009 | 11:42 AM
fcm's Avatar
fcm
Old Fart
Yes you can, if your alarm does not have an "extra sensor" input, remember, if splicing into the "stock" shock sensor leads, you must install diodes on both the trigger leads on both the shock sensors to prevent the sensors from interfering with each other. 94
delsolo95
Audio / Security / Video
Mar 13, 2012 07:21 AM
ek99si
Mar 14, 2010 08:19 PM
kleen98accord
Sep 12, 2009 05:59 PM
Dub C
Aug 7, 2008 05:20 AM
Odessa
Aug 25, 2004 08:31 AM
