obd1 engine with obd2 wire harness
Old Sep 1, 2009 | 12:35 PM
sol-oto's Avatar
Default obd1 engine with obd2 wire harness
will this work if i use obd2 harness on an obd1 engine?
Old Sep 1, 2009 | 12:43 PM
Frost7177's Avatar
Default Re: obd1 engine with obd2 wire harness
you will need a jumper harness for the distributor to use the obd1 dizzy to the obd2 harness you can get off passowrd jdm and you need a jumer harness for the actual ecu itself obd2 to obd1 and depending if its a vtec engine you need p28 and for non vtec a p06
Kdx
Feb 26, 2018 08:08 AM
Prudz_lude
Dec 3, 2008 06:41 PM
2wheelhunter
Jun 4, 2007 04:18 PM
97DGreenEx
Oct 13, 2006 06:21 PM
