d16 Tranny Differential ?s
Old Sep 1, 2009 | 09:01 AM
Crossbreeder's Avatar
Default d16 Tranny Differential ?s
Just got an si/ ex tranny for my ej1. [my coupe is an ex and theres a dx trans in it for some reason.. ]
So before i just dropped it in i took it apart to check the syncros so i dont have any damn grinding action goin on.
Everything look good until i got to my diff... the housing where the pin sits is cracked.. and badly. so now i have an issue..
Does anyone have or no how to get another diff?
Does anyone no if i can put my dx's diff in the si/ ex tranny? and if diff ring gear have the same amount of teeth on the si/ ex? [70]
Any help/ info will be highly apprecitated<3
Old Sep 1, 2009 | 09:07 AM
Aquafina's Avatar
Default Re: d16 Tranny Differential ?s
No, you can't put the DX diff in it.
I can set you up with a stock EX diff or MFactory LSD.
Old Sep 2, 2009 | 05:23 AM
Why cant i use the dx one.. and how much for for the stock one and lsd?
Bump Bump Bump
Old Sep 2, 2009 | 06:50 AM
cpl rampage's Avatar
the ex's use 40 mm diff bearings, dx etc use 35 mm or something smaller. i also have 2 stock ex differentials, one with ring gear and speedo, and one that is bare. 30 for the bare, 40 for the one with the ring gear etc. OBO. PM me.
hers some pics:
Old Sep 2, 2009 | 07:19 AM
92ehatch's Avatar
cant he put the EX gears in the DX tranny?
i know alot of D series tranny internals can be swapped around, but im not sure about this
Old Sep 2, 2009 | 07:49 AM
That was my next question, if i could just swap the gears into the dx trans. Let me no. Thanks for the help tho fellas.
Old Sep 2, 2009 | 08:44 AM
sorry i dont have a deff answer for you, i know you can swap some gears over to create a better ratio for your setup, but im not sure if you can swap the whole stack strait in. the other thing to consider, mfactory are the only ones that make an aftermarket diff for the 35mm housing, everything is for the ex trans, so think about that if you plan on upgrading, because availability would be better for 40mm parts.
Old Sep 2, 2009 | 10:57 AM
Aquafina's Avatar
You can change the complete stacks over, but you'll need to shim the mainshaft. This takes about $250 worth of tools to do.
The MFactory 35mm LSD is on pre-order right now. If anyone needs more info on it, PM me.
Old Sep 2, 2009 | 11:11 AM
92ehatch's Avatar
can get 2 ex tranny's for that price lol
Old Sep 2, 2009 | 01:36 PM
Aquafina's Avatar
Or you can send it to someone like myself who has the tools.
Old Sep 2, 2009 | 01:59 PM
Jimster480's Avatar
or you could just swap the final drive into the Dx and have basically the same damn gears. Considering that the Dx and EX have the same ratios except for 2nd gear and final drive. The 2nd on the Ex is a little shorter.
'But how do you install a Dif into the tranny? is it hard to do? because I want to get one of those OBD-R LSD's for my tranny (DX) but idk how to put it in and I dont want to send it out to do it because i dont want the car to have any real downtime.
Old Sep 2, 2009 | 05:51 PM
Aquafina's Avatar
Wrong. EX 2nd is 1.909/1.900, DX is 1.761/1.781. EX 3rd is 1.250, DX is 1.172. Those are big differences.
DX drops 357 more RPM going into 2nd, 10 RPM more going into 3rd, and 354 less RPM going into 4th.
With the EX 4.250 FD, the DX tops out at 36, 65, 99, 128, 166
The EX tops out at 36, 61, 93, 128, 166
The only advantage the DX with EX FD has is 4th will accelerate faster when shifted into from 3rd, from a 4th/4th roll, they will accelerate the same.
If racing from a stop, the EX trans will win, as the DX trans (even with 4.250) is going to be significantly slower in 2nd.
OBX doesn't make a LSD for the small bearing cases (A000), only MFactory does.
Old Sep 2, 2009 | 05:56 PM
Jimster480's Avatar
wtf well according to this Table that i found it has the same gear ratios except for the final drive and the 2nd gear. So the table must be wrong then? I've actually found like 3 tables and they all have different things on them, but on all of them the DX and the EX are the same (this is for 96-00) idk if your talking about older model trannies because I know those are more different.
How much does a MFactory LSD cost?
Old Sep 2, 2009 | 06:19 PM
Aquafina's Avatar
They are different, 92-95 and 96-00. I've had them all apart and counted all of them.
Freshdot
Apr 2, 2011 09:44 AM
Freshdot
Transmission & Drivetrain
Apr 1, 2011 10:43 PM
JMelt4
13
Jul 20, 2007 12:46 PM
EK45VTi
16
Oct 31, 2004 03:05 AM
JonGP4
Jul 22, 2003 10:10 PM
