after putting oem wheel on it super loose
Old Sep 1, 2009 | 07:41 AM
rick_rabies's Avatar
I'm not Rick!
Default after putting oem wheel on it super loose
Hi duders. I recently put a manual rack in the car. works great. I put a cheap ebay 320mm wheel and quick release on(junk) and when I would go down the road and hit bumps it would jolt the wheel. So..i put the stock wheel back on..now its super loose. Rack is fine. it’s the size of the wheel. Its just slopping feeling and when I hit boost its all over the road.
Any body deal with this before? What did you settle on? A fancy expensive small wheel?
I wish I could tighten up the steering. (im not switch out another rack..again)
Old Sep 1, 2009 | 09:08 AM
rubikscube's Avatar
Default Re: after putting oem wheel on it super loose
Sounds like it got bad when you installed the aftermarket one. Are you sure everything is nice and tight?
Old Sep 1, 2009 | 09:12 AM
bar'dh22's Avatar
try an aliment
Old Sep 1, 2009 | 09:13 AM
thumper64's Avatar
Could the aligntment be off from switching racks? The manual rack is a little looser feeling than a power rack, just from the difference in the gear ratios between the power and manual racks.
Old Sep 1, 2009 | 09:25 AM
Frost7177's Avatar
sounds like you didnt put the wheel on right.
Old Sep 1, 2009 | 09:26 AM
Slo-mo's Avatar
^thats what im thinking.
Old Sep 1, 2009 | 09:40 AM
I'm not Rick!
..its on right, ive done this a million times. but both wheels have cons to them.
i have solid motor mounts and traction bars. the car is super stiff. the wheels are aligned. it goes straight right down the road but its harder to keep a straight line when i hit boost with a big wheel. its like a semi truck wheel compared to the other one its all over the place. ima just buy a fancy wheel i guess.
Old Sep 1, 2009 | 09:42 AM
lluks_844's Avatar
you changed the rack and pinion? and did not get an alignment?
get an alignment.
Old Sep 1, 2009 | 09:43 AM
I'm not Rick!
i did..nevermind.
Old Sep 1, 2009 | 09:44 AM
rubikscube's Avatar
Get a quality hub and quick release wheel, and then an alignment.
Old Sep 1, 2009 | 09:50 AM
kaiba's Avatar
Go back and check all the bolts you unbolt. Get an alignment, check wheel bearing, etc.... Freaking 09
Old Sep 1, 2009 | 11:08 AM
I'm not Rick!
wheel bearings are new, i had an alignment and all the bolts are tight. dont be rude.
Old Sep 1, 2009 | 11:15 AM
Anon51's Avatar
if the wheel turns when you hit boost its called TORQUE STEER. get a tune for a more gradual power band and not just a ridiculous one that goes straight up at boost. or grow stronger arms.
Old Sep 1, 2009 | 11:19 AM
I'm not Rick!
not one answer is related to my question.
i didnt have a problem with torque steere with the small wheel. it was nice, just not when i hit bumps, the cheap ebay quick release was too shaky and it would just jolt and seem unsafe .(other posters should be catching on about now)(hopefully)
has anyone driven a large large truck with a big wheel? well the stock weel feels like that.
Old Oct 2, 2009 | 05:42 AM
I'm not Rick!
update it was the weels. i put steelies on and it went away....
i put the rotas on another 4dr...and that car ended up being squirly
its not the rims. they arent bent. the front tires are bald drag radials..so any1wana by some slipstreams
quirarte626
12
Jun 25, 2009 10:49 PM
grog
35
Jun 11, 2008 01:43 PM
ntensehonda
Honda S2000
Jan 28, 2008 08:06 PM
civic_driver
33
Dec 7, 2005 11:19 PM
civic_driver
10
Oct 12, 2005 06:10 AM
