Is 70$ cheap for D series V-tech head
Old Aug 31, 2009 | 10:03 PM
Rand The Man's Avatar
Default Is 70$ cheap for D series V-tech head
Also would i just be able to bolt on or would i run into any problems?
Old Aug 31, 2009 | 10:06 PM
98civdx's Avatar
Master Detailer
Default Re: Is 70$ cheap for D series V-tech head
how the hell are we supposed to know
what kind of engine do you have?
what does the head come with?
whats the condition of the head?
what kind of head is it??
we need all this information before we can do anything beside guess.
Old Aug 31, 2009 | 10:07 PM
Also I dont think this is going to work i have a 97 ex coup with the 1.6 sohc and i dont know which one it is the heads a d16z6 would this work for my motor?
Old Aug 31, 2009 | 10:15 PM
Corksil's Avatar
d series motor = single OHC
b series motor = dual OHC (vtec)
Old Aug 31, 2009 | 10:35 PM
98civdx's Avatar
Master Detailer
and that has what to do with his question??
i hope he knows you cant put a b series head on a d series.
Old Aug 31, 2009 | 10:38 PM
jyacoba2009's Avatar
lol that would be funny, b heads on a d block. >.>
just for the head, 70 bucks? idk its your call, are you getting anything with it? you check if it has warpage and what not? where you finding this? other than that.. 70 bucks aint bad for a vtec head
Old Sep 1, 2009 | 05:48 AM
xXB18EKHatchXx's Avatar
If you have a EX, you should already have vtec.
Old Sep 1, 2009 | 06:03 AM
92ehatch's Avatar
its amazing none of you will answer his question in the title.
obviously we cant answer, "will it bolt on"
but we can answer that, yes $70 is a good price for a d series vtec head, if it is in good condition, hells its a decent price for a used head that needs minor work
im going to assume that he has a d16y7 or a d15b7 (dx model) civic between 92-00.
it will bolt on to the block, but there are some slight modifications need to do so, and we need to know what motor/car you currently have before giving any final answers
Old Sep 1, 2009 | 06:09 AM
We do know what he has. Hence the he should already have vtec comment.
Old Sep 1, 2009 | 06:15 AM
92ehatch's Avatar
i didnt see that post. thanks for pointing that out.
i agree with b18ekhatch with Xx's
dont bother, you already have a vtec head
Old Sep 1, 2009 | 06:37 AM
Kista20's Avatar
if the op has the original engine in his car they have the d16y8 which has vtec but it's not stamped on the valve cover. I had people arguing with me after I bought my hx because it does have vtec but all 96-00 sohc engines have a plain valve cover that just says honda. And yes I do have vtec-e which is just another form of vtec.
also the d16z6 is from the 92-95 civic which is obd1, the 96-00 civic's are obd2 so to use that head on your engine you're going to have to convert from obd2 to obd1 which is more than what I wanna get into right now but we need more info to be able to help you more.
Old Sep 1, 2009 | 06:43 AM
wannaBjdmca6's Avatar
you guys stop beating around the bush.
an OP u already have vtec
do your research about UR OWN car 1st
ur car came with d16y8 non vtec on ur car would be d16y7 but u have an ex model so vtec fo u OK!
end this threaddddddddddddddddddddddddddd
Old Sep 1, 2009 | 06:56 AM
JDM_SOHC's Avatar
unless his y8 blew, a non vtec motor was dropped, and he misses vtec so bad he wants to rejoin his connection with it than he'd need a vtec head... and YES $70 for a vtec head that's complete is a good deal IMO...
Old Sep 1, 2009 | 08:49 AM
300whpej's Avatar
thats not something i consider cheap, because in my area, you can find a complete swap for around $20
Old Sep 1, 2009 | 09:20 AM
Frost7177's Avatar
yea stolen for sure
Old Sep 1, 2009 | 09:25 AM
Slo-mo's Avatar
^^haha most likely stolen..at least out here in cali
Old Sep 1, 2009 | 12:22 PM
300whpej's Avatar
sorry for the epic typo, i meant $200
Old Sep 1, 2009 | 03:48 PM
TheJGB3's Avatar
Wait a minute if the OP has a '97 EX, he already has a 'D' series SOHC VTEC head. So there is no need to buy what he already has.
TeeB16
Aug 29, 2009 04:33 PM
N7J3H2C
Jan 17, 2008 08:59 PM
AK77
Feb 15, 2007 10:51 AM
REESE1
16
Aug 14, 2003 12:03 PM
