New Shock Install
Whats a good price to get new shocks installed?
I'm thinking about doing them myself if it is super expensive but I have never done them before.
I'm sitting on eibach pros right now. Eibach shocks are freakin shot. I'm going to buy tokico blues.
do not waste your money on the blues. the rears actually have less rebound than oem. for the same money you can buy koni str.t shocks which are MUCH better. as far as the install goes. if you have never done it, have someone help you the first time. that's basically my advice for anything you haven't done car wise. you might need an impact gun to break the top nuts on the shocks. other than that simple hand tools and a jack are all that's needed. if you have shortened springs already it should go pretty easy. oem springs will require a spring compressor. most aftermarkets are short enough they do not.
Razor
Dec 18, 2001 07:06 AM
