accord brake lamps
reason why the brake lamp light would be on, on the cluster?
anyone had this happened to them? all lights in working condition. nothing wrong with ebrake. brake fluid where it should be. took all bulbs out to inspect, nothing out of the norm.
im stump. this is on a 99 accord coupe v6
Lamp warning sub-cluster?
Fluid level sensor connector.....
ABS?... have it checked, don't screw with it.
P
Yes, I have the same problem (94 LX Coupe) "Brake Lamp" indicator is lit. No lights out, all working properly with new bulbs. I'm wondering if anyone knows if the bulbs on this make and model should be single element or dual element? It seems this system depends on proper grounding to shut off the Brake Lamp light, not really sure how to test that. Any help would be appreciated.
usama7
Jan 10, 2012 06:37 AM
mrma8328
Jan 30, 2005 10:38 PM
EuRoBrO
Dec 1, 2003 01:32 PM
