what should one expect from dropping in ITR cams?
just curious if i would see any signfincant gains from dropping some ITR cams into my GSR. i wanna know ifs its worth the money..
this thread is a waste of space.
you know nothing of what you are thinking of doing.
ok, ill be a little nicer and tell you "Dropping in" cams is a waste of cash without any tuning, and with a stock redline.
[Modified by VTECDC2, 7:45 PM 8/26/2002]
Moderator-- throw Soup **** off this as his comments have no place here. I to would like to see more feed back on the subject of ctr cams in a 94 gsr. I have cold air box, headers, and slightly worked over head and modified ECU. My rev limiter is gone.
what do u guys think about CTR cams? which is more agressive, CTR or ITR cams? i heard CTR exhaut cam and ITR intake cam is the way to go.. (or was it the other way around?)
If you have a little extra money, save for the Skunk2 Stage I. Or Stage II if you have cash for upgraded valvetrain, pistons, etc.
Will you see much gain using your stock cam gears and valvetrain? Or is it a waste without new cam gears and tuning? How can you change your redline without sending your ECU off, can it be done by someone with a laptop?
I've had untuned ITR cams in my car for over half a year now and it's an improvement over stock even without tuning. The only problem is that there is a dip in power just before vtec hits but after that it pulls hard all the way to redline. I've finally decided to get off my *** and get the car tuned this month.
[Modified by Dirty GS-R, 1:48 PM 9/3/2002]
X2BOARD
Sep 16, 2004 11:06 AM
