Wierd Whining Noise in Guage Cluster??
Old Aug 30, 2009 | 04:27 PM
JDMoneDC5's Avatar
Default Wierd Whining Noise in Guage Cluster??
Well, this is my first ever experience with DA integra Ive only delt with CRX's and RSX's. Always been a fan and Knew I was sooner or later gonna end up with one. So Piked up my bro's DA9 and now is a fixer upper. Little problems here and there but one really bugs the crap out of me. The Car runs Extremely well but for some reason when I hit above 20mph there is this wierd Whining noise coming from the Guage Cluster. I have purchased a new One (in order to fix my Temp Guage due to its not working). Wondering if that will fix the problem.
Anyone else familiar with this issue??? Thanks
Old Aug 30, 2009 | 04:54 PM
Devon M's Avatar
Default Re: Wierd Whining Noise in Guage Cluster??
I have the same issue. I believe that it has something to do with the cable as the tach is run off a cable instead of electronically. I just bought my Da as well and was hoping to just put some oil on the cable. Lmk if you fix your problem.
Old Aug 30, 2009 | 10:16 PM
JDMoneDC5's Avatar
Definitely, it seems the sound is coming from the Speedometer. I will see if switching out my Guage Cluster will fix it. and Post the results. And ill check the cable aswell as seeing that also might be the prob.
Old Sep 17, 2009 | 01:34 PM
JDMoneDC5's Avatar
Well after a couple weeks of Procrastination, i took my dash apart and swaped out my Cluster. The Noise is from the Speedo and the Cable, I think its more of the Cable. and My Thermo guage flickers on and off but now I know that it has something to do with the wirering from the thermo stat seeing that its been spliced and connected with Butt connectors. So, I guess its time to get back to work.
Walterronny
Jul 28, 2015 04:19 PM
Charlie Moua
19
Sep 19, 2011 10:30 AM
peanut butter
Feb 18, 2008 04:00 PM
saikouEF8
Jan 26, 2006 08:41 PM
02WRX
Mar 7, 2002 05:47 AM
