Wiseco Pistons H22A
Old Aug 30, 2009 | 04:15 PM
VEGAN_EG's Avatar
Post Wiseco Pistons H22A
Building an h22a starting with the block and moving up.
block is getting sleeved here shortly, just looking into what pistons to get
Im looking to run a high compression motor with a direct port nitrous shot (~150 shot), built top and bottom end.
(head = new valvtrain, crower stage 2or3 na cams???, ported/polished, etc etc)
I want to keep the stock bore (87mm) and stock rods.
looking at the wiseco 11.5:1 pistons. anyone with experience with these?
will they hold up to nitrous? and high rpms?
looking for all suggestions here good and bad, still in the beginning stages of this new motor
Old Aug 30, 2009 | 04:23 PM
ek9poormanr's Avatar
Default Re: Wiseco Pistons H22A
wisecos are good arias srp probe rods eagle rods manley rods cp pistons are good
Old Aug 30, 2009 | 04:39 PM
VEGAN_EG's Avatar
hmmmmm
so now its a tossup between CP 11.5 and wiseco 11.5
any other comments/suggestions?
Old Aug 30, 2009 | 04:40 PM
robfrmny21's Avatar
cp are greats pistons
Old Aug 30, 2009 | 04:42 PM
VEGAN_EG's Avatar
any pros/cons of the 2???
or a link to a thread on it?
Old Aug 30, 2009 | 06:07 PM
runbycommies's Avatar
why are you sleeving if your gonna go all motor save some money and get forged pistons that will run in stock sleeves
Old Aug 30, 2009 | 06:21 PM
VEGAN_EG's Avatar
FRM sleeves FTL!
no bueno with lots o N2O
and one of the stock cylinders has a scar.
Old Aug 30, 2009 | 06:34 PM
dlaub25's Avatar
The Wisecos come with more features off the shelf than the CPs do. They come with moly coated strutted skirts and offset wrist pins if I'm not mistaken. CP would charge extra. CP makes very nice pistons as well. (I have a set in my current project) It just seems like you get more for your money with the Wisecos
Old Aug 30, 2009 | 07:50 PM
Originally Posted by VEGAN_EG
FRM sleeves FTL!
stock sleeves will take 100 shot no problem but yeah with a scar i would replace but not sleeve not worth the money unless your gonna turbo
Old Aug 30, 2009 | 08:05 PM
VEGAN_EG's Avatar
Good info on the pistons thanks!
and i plan on running a 150-200 shot direct port shot and i dont wanna risk it
plus i got the sleeves and installed for under 300
Old Aug 30, 2009 | 08:17 PM
h22ej8's Avatar
Sleeving will be a must for dependability when spraying nitrous.
IMO anyway.
Personally I'm going to be running some arias pistons in my H, i think you'll want to go with a bigger dome piston if you really plan to run crower 3's, i ran them with some 12.1:1 pistons at altitude (which amounts to about 11.1:1) and they really didnt make power until about 7.
Old Aug 30, 2009 | 09:11 PM
god damn $300 for sleeves and installed were did you get that hook up
Old Aug 31, 2009 | 04:46 AM
VEGAN_EG's Avatar
IMO anyway.
ive been looking and cant really find any pistons higher than an 11.5
any ideas on who makes some good ones around 12.5-13?
and if i decide to go crower 2's is 11.5 going to be high enough?
Old Aug 31, 2009 | 06:07 AM
Honda_Mad's Avatar
11.5 would be could for nitrous anything higher than that on a big Nitrous shot would require race gas.
Good lUck
Old Aug 31, 2009 | 06:11 AM
VEGAN_EG's Avatar
i already planned on running 110 vp gas.
just cant find any pistons over 11.5 without going custom
shazbot
Aug 1, 2004 03:51 AM
Bad@$$Blue
Dec 12, 2002 03:28 PM
darkstarsi
Aug 29, 2002 06:45 AM
dvp95
May 15, 2002 11:38 PM
Pinhead
Feb 3, 2002 09:26 AM
