d16 head milled
so if i milled my head .040 i should be able to use the same timing belt right? i need more info on it let me know thanks... some people bfor told me to mill it .040 but when i ask them bout the timing belt they never answer me lol
i've pulled the valves out and millled it all the way down on a single cam.... down to where the valves stuck out past the head.. and used the stock timing belt...
i don't do that anymore because i've taken out a lot of motors that way!! but i was getting D Series motors back then for like 50 bucks each or free. so i didnt really care if they blew up..
anyway.. you will be fine with the stock belt..
go over to one cam only and look up Rushi's D15b2 build. Its got more info/tech in that thread alone than probably half the threads here combined. he milled his d15 head to where he has the valves sticking above surface. He used the WP gear off a b16 WP to compensate for the slack in his Timing belt and the engine is running fine he just has some tuning and intake mani issues to resolve right now but the engine will easily make 200hp with out blinking an eye.
okok well I milled my d16a6 head and use the same timing belt, I have a adjustable cam gear but i dont know how much to degree sorry but i,m new at this can some help me?
Here is a A6 head I milled 80k," if you do a huge mill on a 1.6 motor you can run a HF belt since the 1.6 belts will be too long. On a 1.5L you can swap water pump gears to make up the slack.
the head was milled .040 the block wasnt decked and yes im using the stock 3 layer gasket. Another question, the cars when is under heavy load it start to over heat little by little, could it be the high comp? I have p29 pistons too but the cam is the stock one and the radiator and water pump are fine and the thermostat is new and the hoses too
you need to advance your cam gear by 1 cam (not crank) degree to correct for the milling. If you're HG isn't sealing correctly, that could cause it to overheat. You need to check all the basics.
How can I check that? How can I check thath the headgasket is sealing correctly? sorry for this I dont speak english very well so if you can explain it to me the more simple the better thanks.
Check all the basics like your radiator to make sure it isn't blocked, your thermostat to make sure it's opening properly, your fan switch to make sure it's turning on when it should, your heater to make sure you're getting heat meaning it's not blocked.
When you say that it starts to over heat, what exactly does it do?
If you're not losing any coolant and it's not boiling in your overflow tank, I think it's ok. Sounds like one guage is just a little more sensative than the other.
The OE gauge isn't linear. It's slope flattens out at the beginning and end of the normal temp range. That's why it shows little/no movement during temp. fluctuations. I guess that's the same as saying it's not as sensitive. I wouldn't be concerned if it was my car. The temp is going to fluctuate.
Yeah I had think that too but the only things is that when i'm climbing in the mountains the oem temp gauge its start to tell that is hot but it pulls up than comes normal again then suddenly it pulls up again then puts ok again and on and on untill I'm clear the mountain the put again in normal place, both of them. My friend tells me that it could be the compression and he thinks that I should get a bigger cam but I dont know the only thing my friend manage to do is was to confuse me more...
