Whats My Built B18c1 worth?
Whats up everyone, so my quest for more power continues. Thinking of going H2B. So If people could chime in what they think I could get for my setup and if I should part it. Here is the run down.
Block-
JE 11.5.1 comp pistons
Eagle rods
ACL race bearings
ARP head studs/rod bolts
new oil pump
all oem gaskets and seals.
Head-
Skunk2 pro 2 cams
Rocket Motorsport full valve train gen 1
Blox intake manifold
RC 310 injectors
Golden Eagle pro series fuel rail
Full king stud kit for intake manifold
mild port and polish
oem head gasket
Omni Power Throttle Body matched to the mani
Jet coated smsp header
The motor is in great shape, about 8K on build. Motor put down 202whp before Vstack
Let me know what you guys think would be fair to ask for the motor. And if it would be smart to part it out? I don't want to ask way to much and I also don't wanna sell it all and not have enough cash for the h2b kit and H22, header and cams!
Thanks for the input everyone
Block-
Eagle rods
ACL race bearings
new oil pump
Head-
Skunk2 pro 2 cams
RC 310 injectors
oem head gasket
understand, what you spend on a piece doesn't exactly warrent you getting what you spent back.. if you buy a set of cams for 600 dollars, more then likely you'll barely get 4 for them..
this motor, and what it has done, a fair price would be 2k.. considering the risk involved, reguardless of who did the work, and what not
2k is a fair price, if u can findsomeone to pay more, great.. i'm just saying what i'd pay for this motor.
Well yeah i know that, I was thinking of putting on craigslist for 3500 with header then go from there. Thanks everyone for the input.
Also, do you guys think that an h22 with some cams and bolts will be significantly faster than this b setup, both running the usdm itr trans?
DoWork17
21
Aug 24, 2009 04:11 PM
EvOsweenS
Aug 16, 2009 05:13 PM
EvOsweenS
Aug 3, 2009 10:22 AM
