crx dpfi to mpfi
Old Aug 30, 2009 | 08:22 AM
crxb16a90's Avatar
Default crx dpfi to mpfi
i done many dpfi and mpfi swap, always start up no problem what so ever.
but this time is the first time, it won't start. i helping a friend to get his car going. his wiring was touch by someone else, so far everything line up.
i am not getting any spark. got fuel but no spark, any idea.
Old Aug 30, 2009 | 08:38 AM
89s1's Avatar
Default Re: crx dpfi to mpfi
recheck the wiring. If you're sure the wiring is good, check the dizzy on another known working engine.
Old Aug 30, 2009 | 10:18 AM
crxb16a90's Avatar
yeah, i did all that, wiring is good so far i know of, i switch that white wire back and forward, dizzy is good. but i am not sure the angle of the dizzy, i thought the single cam doesn't sit the same with single cam. so i thinking i have the dizzy too far turn out. may be not. i know its a common problem. just try to remeber what it was.
Old Aug 30, 2009 | 10:52 AM
garageEF's Avatar
Umm...What?
The motor should start regardless of where the ignition timing(distributor) is set, assuming you are using the correct motor/dizzy combo.
I would start by checking all of your wiring.
Old Aug 30, 2009 | 02:52 PM
crxb16a90's Avatar
is a single vtec, using si dizzy, using obd0 wiring, and pr3 ecu. i just not getting any spark.
well is not timing part, i just wonder the dizzy is turn too much like 90 degree. but i thought so to, it should have some spark. miss fire or something. someone screw him on wiring, and took his money never finish it. i just trying to get him going. so finding what the hell that guy did. be pretty hard. i check all the wiring, i think no.1 and no.3 injector are switch, but still would get spark. i not getting any spark at all.
ACK94
Classic Hondas
13
Apr 12, 2010 02:09 PM
KiLlInG 562
Sep 30, 2006 04:52 PM
VRD^don
26
Jun 1, 2006 11:00 PM
