cams skunk2 or?
Old Aug 26, 2002 | 05:08 PM
flashgsr's Avatar
Default cams skunk2 or?
Have 01 gsr skunk2 intake mainfold, aem cai, fuel regulato/rail.
would like to find a high perfomance set of cams that would be easy daily driven with good idle (and winter driven) for under $1500 canadian.
Old Aug 29, 2002 | 07:34 PM
b16a2pwr's Avatar
New User
Default Re: cams skunk2 or? (flashgsr)
I have a set for salee.. they're brand new. email - b16a2pwr@hotmail.com for info
Old Aug 29, 2002 | 08:02 PM
RedTeg95's Avatar
I got some Skunk2 stage 2 cams for sale on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...854556289&rd=1
Old Aug 29, 2002 | 08:33 PM
TEG2001's Avatar
I have seen a set of Crane cams for 800 cad of coarse which are suppose to be pretty good, then I have also seen Cat cams for 499 that was here in Edmonton. How is your intake manifold?? I heard that if you have a stock top end the manifold sucks and you loose lots of bottom end is this true??
Old Aug 29, 2002 | 09:02 PM
Tweakmeister's Avatar
I'd recommend Skunk2 Stage 2's
or TypeR (or CTR)
keep in mind you'll need beefier valvesprings as well.
Old Aug 29, 2002 | 09:17 PM
StinkyTofu's Avatar
Default Re: cams skunk2 or? (RedTeg95)
Weren't you the one to make 17x.xxhp with your skunk2 stage 2 cams?[QUOTE]I got some Skunk2 stage 2 cams for sale on ebay...
Old Aug 30, 2002 | 09:33 AM
skunked's Avatar
I would recommend Skunk2 stage 1. You can use your stock valvetrain and daily drive on them without any problems. Unless you want to get a little more involved and change the valvetrain, then I would go with Stage 2. It all depends on the $ you want to spend and what your plans are for your car.
Old Aug 30, 2002 | 09:54 AM
wonny's Avatar
Default Re: cams skunk2 or? (skunked)
that is exactly what I was thinking.
Get the stage one. That way you don't have to mess around with anything else.
Simplify!
Dave
Old Aug 30, 2002 | 12:35 PM
Blade's Avatar
New User
Default Re: cams skunk2 or? (ridge racer 2)
Crower Road Race
you mean the Toda copies? Does Crower do any of their own R&D or do they just copy JUN and TODA? And even when they copy, they can't do it right so their cams keep breaking.
[Modified by Blade, 1:36 PM 8/30/2002]
Old Aug 30, 2002 | 07:04 PM
four27's Avatar
Default Re: cams skunk2 or? (Tweakmeister)
Tweak-- What do you think of dropping ctr cams in to my 94 gsr. this subject probably has been beat up but I am new. My car has a OPM prepared head with 025 milled off. I have header with pretty much open ehaust and a cold air box. the car is only used for road racing I got a cheap set of civic type r cams and wonder how they will work with my stock springs and retainers which are new. I also have a modified ecu with rev limiter deleted. I do have the shift lite set at 8500.
Old Aug 30, 2002 | 09:25 PM
Default Re: cams skunk2 or? (four27)
personally, I'm a little more conservative when it comes to making sure things are reliable. While I'm sure you can run the CTR's with your current springs, I wouldn't go revving that high on an extended basis with those cams.
there was a previous thread where a gs-r owner mentioned running ITR cams on an otherwise stock valvetrain without any problems....keep in mind that's a stock rev limit.
Personally, I would go ahead and get the beefier valvesprings. Portflows if you can afford them, or pretty much any other of the good springs out there work ( http://www.importreview.com) . At the very least get some ITR springs (they can be had for like $100 used here). All B-series retainers are the same. The ITR valves are a little ligher which makes a difference again. Also, with your head milled (the increased compression is great) but that leaves even less room to play with for valves.
Old Aug 30, 2002 | 10:24 PM
RedTeg95's Avatar
Default Re: cams skunk2 or? (StinkyTofu)
Yes I was, but I just dropped a turbo in so I don't need them anymore.
just_dung
Northwest (Sales)
Jun 24, 2010 09:32 PM
panda_eh2
May 1, 2008 08:16 AM
GSR95T
Nov 18, 2004 05:13 AM
1quik95gsr
Mar 19, 2003 09:35 PM
