air/fuel ratio????
Use what MTber says.
Although tune for a flat AF ratio under load then fiddle with AF ratio later increase and decrease and see if that does anything for horsepower, I think the gsr and H22 are about the same in regards to wanting a richer AF under wot.
The problem with giving tuning advice on a forum without seeing the engine are all engines are different. although once you grasp concepts you can see if the changes you are making are helpful or worthless.
read some books too it will open your eyes to tuning.
Hope that helps, good luck.
HotWheelz
Nov 7, 2003 02:34 PM
