only gained 15 hp
Old Aug 29, 2009 | 01:14 PM
lostkoz's Avatar
Default only gained 15 hp
i have an h22a us block with an h22a jdm head.hit 170 last dyno had this done. supertech springs and retainers.valves to.5 angle valve job and oversize valve seats. skunk2 stage 1 cams.
is 15 wut it is with that stuff i had done.
not bitchin about it. just wasn't sure how the results would be. i thought the top end power would of been more, but no more lag in the midrange. if i knew how to post pics you can see the dyno.
i figured more cause the bolt on's. aem tru time gears,aem cold air,megan headers,greddy 60mm catback exhaust. the throttle body has been bored out by jg dynamics and an afc2 v-tec controller.
Old Aug 29, 2009 | 03:20 PM
Top Ramen's Avatar
Default Re: only gained 15 hp
wut x-actly ru asking. is this just about the cam and valve job and can u use some grammar. please.
Old Aug 29, 2009 | 03:40 PM
BigBlock22's Avatar
this one really is a doozy
Old Aug 29, 2009 | 05:40 PM
drag_killer's Avatar
get high comp piston,hehehe if you want more power
Old Aug 29, 2009 | 09:37 PM
Combustion Contraption's Avatar
You user name is more than appropriate.
Old Aug 29, 2009 | 10:57 PM
boxeocampeon's Avatar
umm if im not mistaken the h22 motor is like 200hp stock so that means you lose a good amount of power?
Old Aug 30, 2009 | 01:05 AM
.Manny.'s Avatar
Touching My Member
that would be crank horsepower noob, whp is always less. A 15 whp gain is reasonable. how much were you expecting?
Old Aug 30, 2009 | 04:03 AM
00Red_SiR's Avatar
All Motor Mentor
Especially if it was a 15 whp gain. But everyone knows that the real secret is in the stickers...if you forget to put one on, that's like 5 whp right there.
Old Aug 30, 2009 | 07:55 AM
1.5Slowmatic's Avatar
did you retune it?
Old Aug 30, 2009 | 08:08 AM
Frankacura's Avatar
i use type S cams and im verry happy of the result... Over 170 WFP torque and Over 230Whp 15% remooved at the dyno 270HP
Old Aug 30, 2009 | 08:23 AM
DDTECH's Avatar
I'm assuming your one of those guys who thinks thats because on the site it says you'll gain 12 whp across the board with those cams you believed them.
Every motor reacts differently to everything done... Basically you put a stock cam in, expecting alot of power, 5 angle valvejob? For what.. your not making 800whp and trying to squeeze everything.
Want the honest to God truth? i think 15whp for what you have done is good.. 185whp h22 with just some head work and cams? Thats pretty good bro..
I'd also visit silva learning centers too.
Old Sep 1, 2009 | 05:32 PM
lostkoz's Avatar
well you all comics.the motor dyno at 170 when i put it the car. now its 185 to the wheel. wanted to see more at top for that i need to change my stockass ecu. mid range has the hardest gain about 30 hp. the tourqe is 142 across the dyno. v-tec is smooth when it kicks in.
Old Sep 2, 2009 | 12:34 PM
88Hatchy's Avatar
So you're complaining about a 15whp gain without any tuning?
Old Sep 2, 2009 | 12:45 PM
king06's Avatar
^That's what it sounds like.^
15hp with no tuning is in my opinion, really good.
Get it tuned and keep us posted.
Old Sep 2, 2009 | 12:56 PM
thundernoodle's Avatar
um I'd be happy with a 15whp gain with those cams
Old Sep 2, 2009 | 01:08 PM
h22aCb7's Avatar
Hell ya, and with no tuning!!!
Old Sep 2, 2009 | 01:14 PM
www.megameet.org's Avatar
get hondata and TUNE IT, and you should have done springs/retainers/valves and stage 2 cams.
Old Sep 2, 2009 | 01:31 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
did u expect supertech springs and retainers, and valve gain u ponies?
i wouldn't expect a ton unless you did full intake, exhaust and a port job
Old Sep 2, 2009 | 01:48 PM
Top Ramen's Avatar
I still think adding grammar would give you a performance increase . . . .
Old Sep 2, 2009 | 08:34 PM
omniman's Avatar
come on now its obvious english isnt his primary language. funny how its hard to say what you want more and more when this is becoming the customer base.
Old Sep 3, 2009 | 02:15 PM
EGHATCH4YA209's Avatar
So well put.
Old Sep 3, 2009 | 09:22 PM
honda-will's Avatar
why do all that work for stage 1 cams? if you want a dyno ***** just change your cams. and GET IT TUNED!!!!
Old Sep 6, 2009 | 08:19 AM
lostkoz's Avatar
98vtec
32
Mar 23, 2015 11:42 PM
coomplife05
Aug 9, 2013 02:07 PM
95exdsmkilla
Nov 13, 2011 06:04 PM
Adam.
134
Aug 12, 2005 10:05 AM
