What to check. CAR WONT START.
Old Aug 29, 2009 | 12:38 PM
danielfleenor's Avatar
Default What to check. CAR WONT START.
My brother has a 91 teg. B18a1 hey took the neg off the battery and it won't start after. He called me and I told him to check the fuses and check for spark and fuel. I don't know how to check for spark and fuel. What should I tell him. Plus is that all that it could be??
Old Aug 29, 2009 | 12:42 PM
axelintegra's Avatar
Default Re: What to check. CAR WONT START.
When you turn the key to the on position listen for the fuel pump. It could be shot.
Old Aug 29, 2009 | 01:20 PM
vrod's Avatar
New User
Does he have a alarm system
Old Aug 29, 2009 | 01:31 PM
fcm's Avatar
fcm
Old Fart
Need more info.
Along with the above questions, when you say "won't start after" what do you mean,
after what exactly, was the batt. neg.(-) just disconnected and then reconnected or was something else done, [new batt. or some other work on engine]?
When trying to start the engine will it not turn over, [crank] or does it turn over but not start? 94
Old Aug 29, 2009 | 05:20 PM
Stock motor. Not a new Battery. No alarm.
Old Aug 29, 2009 | 11:03 PM
boxeocampeon's Avatar
make sure to tighten the negative ring around the post because it might not be getting a good connection. Theres a tool you can use to clean the post and the connector. Try that if not take the plugs out and see if they are black at the end.
Old Aug 30, 2009 | 05:54 AM
fcm's Avatar
fcm
Old Fart
"When trying to start the engine will it not turn over, [crank] or does it turn over but not start?"??????94
Old Aug 30, 2009 | 10:56 AM
it wont start.....now hes say every time he goes to start it the ecu fuse blows.
Old Aug 30, 2009 | 05:30 PM
phootbag's Avatar
Why did he disconnect the battery to begin with?
Old Aug 30, 2009 | 05:51 PM
94civic96's Avatar
we need more info to help you.... like what does the do exactly b specific and write a lot if you have to for us to help
Old Aug 30, 2009 | 08:53 PM
phootbag's Avatar
Shorted main relay? Hook up the battery backwards?
Old Aug 31, 2009 | 05:37 AM
fcm's Avatar
fcm
Old Fart
I understand it will not start, so one more time....
"it wont start" does not answer the question.
As mentioned, for us to help we need more info, playing post tag takes way too long.
So....
1- does engine turn over but not start or will it not turn over at all?
2- why was batt. disconnected?
3- what is the fuse number, there is more then one fuse related to the ECU?
4- was the "ECU" fuse blowing all along or is this something new?
5- can you hear the fuel pump prime, [running] the fuel system when ign. key is turned on?
Please answer all the above questions. 94
nate10498
14
Jan 18, 2009 08:56 PM
yahboyryan
Mar 13, 2008 06:12 PM
s_vares
Feb 16, 2007 07:21 AM
civic efb16
Aug 8, 2005 09:00 PM
posterchild
Jun 26, 2004 02:09 PM
