1991 crx
i want to swap a d16y7 into my 1991 crx dx. what parts do i need to make this swap? i think i need a new dizzy,ecu,wire harness?? and the d16y7 is multi port and the crx is dual port does that matter? thank you.
you can run the y7 dual port and use all the stock dx parts like the intake mani dizzy and ecu. or if you want it mpfi you need to rewire your stock engine harness for that. then youll need a dizzy and ecu from a d16a6 if you wana keep it obd0 and easy. just think of the d16y7 as a d16a6 because it pretty much is.
stw88crx
Jan 8, 2005 02:03 PM
