b16a3 transmission and clutch problems
Old Aug 29, 2009 | 06:59 AM
aedwards454's Avatar
New User
Default b16a3 transmission and clutch problems
My 1995 delsol has a b16a3 engine. The clutch has been pretty worn since i bought the car but the clutch wasnt slipping or anything. recently after driving the car for a little it would get hard to put into gears, but sometimes it would be hard and other times its normal. When i first start from a stop, and i start letting go of the clutch, then the whole car vibrates like crazy until i tottaly let go of the clutch. also when i switch gears and if i have my hand on the shifter and say im in 2nd gear and the weight of my hand pull the shifter a little closer to me and i hear a noise like 2 pieces of metal just sliding against each other, like a shhhhhhhhhhhhhh kind of sound, but if i dont have my hand on the shifter and its in gear then there is no noise. Im guessing that hard shifting into gear and vibrating is from a bad pressure plate. And the wierd nosies could be a bad throwout bearing or pilot bearing maybe? Im not really sure because this isnt usually the kind of stuff i do. Let me know what you guys think.
Old Sep 1, 2009 | 09:30 AM
New User
Default Re: b16a3 transmission and clutch problems
bump
CDUB321
Oct 29, 2009 05:59 PM
JZiggy
Jul 19, 2009 05:56 PM
alscrx
Nov 3, 2008 04:27 PM
loco4sho2004
Aug 11, 2008 09:40 PM
Jer'rome
May 26, 2004 02:34 PM
