rod bearings?
Old Aug 26, 2002 | 03:50 PM
StockBlkEK's Avatar
Default rod bearings?
who would have them instock??
Old Aug 26, 2002 | 03:54 PM
Reid's Avatar
Global Moderator
Default Re: rod bearings? (StockBlkEK)
Try your local Acura dealer.
Old Aug 26, 2002 | 04:00 PM
StockBlkEK's Avatar
Default Re: rod bearings? (Reid)
you need to take about the block before you can order them.
any aftermarket places?
Old Aug 26, 2002 | 04:02 PM
Reid's Avatar
Global Moderator
Yes you need to take them apart before you order new bearings.
What's the problem?
Old Aug 26, 2002 | 04:07 PM
StockBlkEK's Avatar
putting in new pistons and like to replace the rod bearing... only time i have is labor day weekend... then i need the car for tue...
havin one car sucks
Old Aug 26, 2002 | 04:11 PM
ImportReview
Guest
Posts: n/a
I have every bearing in stock.
All the time.
http://www.importbuilders.com
tonyxcom's Avatar
Well, if you are abitious enough do this.
Jack up car.
Remove oil pan, pickup and baffle.
Rotate crank so you can see the bearing numbers
write them down.
Contort yourself so that you can read the numbers on the rods. May need flashlight and small mirror.
Reassemble. Put oil back in.
Then get your helms and figure out what bearings you need.
Order them.
Once you have them in hand, get your pistons put in and new bearings on the rods.
Have fun!
pjr710
Aug 18, 2008 11:18 PM
bb4socal
Feb 1, 2007 01:28 PM
DjDrift
Oct 2, 2004 08:05 AM
hybrid901
Mar 17, 2003 11:43 AM
B20zvtecek
Oct 28, 2002 07:11 AM
