My Ported H22a Dyno
Old Aug 28, 2009 | 08:12 PM
Frankacura's Avatar
Default My Ported H22a Dyno
Just got my Dyno results from REDLINE performance
I'm so happy of my great results from my great work
JDM 94 H22a Close deck sleeved 89mm
11.5:1CR
Ported and polish by me
Manley: Valves, springs, reteners
Type S cams (no reteners to guides contact lol) Yes type S cams in non type S head
Stock Ported double runner intake. 4 Throttle remooved
60mm throttle
JDM Jasma headers 3' exhaust
Old Aug 28, 2009 | 08:28 PM
Frankacura's Avatar
Default Re: My Ported H22a Dyno
and this is at the WEEL yes. -15%
270 HP
Tuned HONDATA S200 by www.autolaminar.com
Old Aug 28, 2009 | 10:01 PM
BigBlock22's Avatar
you made great use of those type s cams and stock intake manifold. congrats on the port job... but whats up with the 270whp figure?
Old Aug 28, 2009 | 11:23 PM
SergEK's Avatar
What was your baseline on this dyno before mods and headwork? Flow bench the head?
Great work
Old Aug 29, 2009 | 06:06 AM
flesh199's Avatar
The im porting work look good for sure.Props to you
Old Aug 29, 2009 | 09:48 AM
Frankacura's Avatar
I said 233Whp the H22 made. Whp is at the Weel
At the motor this H22 got 270HP
Old Aug 29, 2009 | 09:55 AM
Frankacura's Avatar
Great work
The motor never been dynoed befor.
I made all the set up myself as y think its supose to be.
but it's my firt H built
Head flow 295CFM at .55 and real number are more in .300 where she did verry great numbers ( 222 cfm ) at .300 lift and ( 259.4 cfm ) at .400 lift
i'm use tu built B serie
http://frankacura.monchar.com/
Old Aug 29, 2009 | 10:06 AM
Frankacura's Avatar
Old Aug 29, 2009 | 10:23 AM
juan3023's Avatar
GREAT NUMBERS !!!!
Old Aug 29, 2009 | 10:46 AM
BigBlock22's Avatar
....sorry i misread that. im sure you spent hours on that head and intake manifold. looks great though
Old Aug 29, 2009 | 11:42 AM
Frankacura's Avatar
About 40 hours on head and 20h on IM
Old Aug 29, 2009 | 12:28 PM
namewasdallas's Avatar
deff nice power outta that motor, that head and IM look nicely done. Good job dude them 40hrs spent did wonders
Old Aug 29, 2009 | 09:22 PM
fastasscivic's Avatar
New User
did you do anything to the bottom end... i want to get an h22 too.. but im thinkn of the itr too....so what do u think
Old Aug 29, 2009 | 10:42 PM
Frankacura's Avatar
11.5:1CR
If u take a type R JDM 98, Keep that thing stock as is. and instal a nice staged exhaust 2 1/2 at headers exit to resonator and 3' the balance and u tune that up to 185Whp 140FPT every time...
Good set up for price.
The H22 here cost Over 6500$ Can. Only on engine... (from valve cover to pan) no intake, headers. exhaust. ECU chiping, Dyno...
Old Aug 29, 2009 | 10:49 PM
Frankacura's Avatar
In RED at Right first dyno run.
In BLACK at Left last Dyno run.
Old Sep 1, 2009 | 03:01 PM
Frankacura's Avatar
Torque never under 150fpt
Old Sep 1, 2009 | 04:43 PM
alterdcreations's Avatar
Very nice. Big h's are really nice
Old Sep 1, 2009 | 05:31 PM
jr_deleon's Avatar
Much props to you for DIY. Though you spent a lot of time on it, you saved a lot of money (not saying that you took long) I'd spend more hours if i knew i was saving 900+ dollars on porting the head alone. But im more impressed with your results. for you
Old Sep 1, 2009 | 05:44 PM
PirateMcFred's Avatar
Not bad numbers for Type-S cams. You're running a little rich and it looks like your midrange torque acts a little odd. What's the ignition timing like there?
Your build is pretty close to what I'm working on but instead of a 89mm bore I'm stroking to 97mm for an extra 50ccs and half a point more compression. I'm looking forward to ~240whp or so.
Thanks for sharing.
Old Sep 1, 2009 | 08:06 PM
teefunk01's Avatar
good stuff
Old Sep 2, 2009 | 12:05 AM
jdm inc's Avatar
ports look good!
Old Sep 2, 2009 | 02:48 AM
kingofbattle909's Avatar
mor pix of the ports and im if possible, please.
Old Sep 3, 2009 | 03:01 PM
Frankacura's Avatar
Thanks for sharing.
Usualy Mick from Laminar dont like to play with basinc timing in ECU.
i just dont know wat's the timing exept for the distributor is 14deg. 91 Octane
Is been leaned of 1 pt at 6000rpm from begening and no power gain...
Old Sep 3, 2009 | 03:28 PM
Frankacura's Avatar
Old Sep 3, 2009 | 03:36 PM
Frankacura's Avatar
Thanks for sharing.
Mine stroked 97mm Will come out at least 10Fpt stronger so about 15Whp more
