suspension problem
Please don't hurt me!
i got my car a while ago and they guy had cut springs and the suspension was really messed up. I put spoonsports nonadj dampers on their and im having the same problem the tires in the back are in toed and wear really quick on the inside and the front 1s wear really quick on the inside is this because I need a camber kit? Thats what I think I could be wrong
well if they are wearing out on the inside it means that the tire is not being distibuted evenly on the road... and a camber kit can fix that... but rip out those cut springs and start off fresh with some new ones
It'll run ya high!
LoL no... it wont
under 300 bucks you'd have all 4 corrected
check for yourself here
http://www.nopionline.com/index.cfm?...lignment%20Kit
that link should work
LoL no... it wont
Do an alignment, out of spec toe will kill your tires 10x faster then off cambers. How much of a drop do you have right now?
Yeah, it sounds like you just need an alignment. Everyone thinks camber kits will keep there tires from wearing out fast, but it isnt true at all.
um my car wont allign I forgot to say that
specs
Front Drop 2.2. Rear DRop 1.7. Front Spring Rate 24k. Rear spring rate 28k.
specs
vdawg559
14
Sep 26, 2008 07:33 PM
originalg00kster
Suspension & Brakes
Sep 24, 2007 12:47 AM
Cosworth
Apr 3, 2002 12:04 PM
supratt
Jan 21, 2002 06:33 PM
