Random Parts (B-series & D-series)
Old Aug 28, 2009 | 06:12 PM
FOMULA91's Avatar
Default Random Parts (B-series & D-series)
My Voucher List
SOLD to:
Itslogz – AEM Cam Gear Bambbrose – OBD0 Injectors Krisfnbs – 2 Hydro VSS harmonator84 – PR4 ECU
Mr_CRX – DA VSS 24TEN – GSR T cover, D16 IM ekillah – OBD1 IACV RSZero1 – PR4 ECU
ca-rs – HF CAT JayGee625 – OBD0 IACV Fonkernuckle – VTEC solenoid mgs1098 – Hydro VSS
slowlittlewhitey – OBD1 IACV b18vtecboi – D Mount FG2 chilotz – OBD1 IACV Obuhmyuh – IACV
Blazinearth – ITR IM SawBoss – P72 PS Pump EJ2-Fluffy – radio, MAP sensor dkboyny11 – ITR CAMS
agustin – Jump Harness stellhornata – cable VSS 95singlecamvtec – MSD cap 818blue818 - FITV
ptftw - Distributor myfirstdc2 – OBD1 injectors eg-perk – ECU connector Navy_CRX – AEM fuel rail
88civic - vtec solenoid triphop718 – ECU connector ==Catfish== - B-series motor mount bracket
srt4pilot – D series motor mount bracket Reza^ - OBDI injectors Group Tenacity – PR3 A/C bracket
EGR95 – B16 Intake Manifold socalJDMer – OBDII injectors d_EG COUPE – traded VSS with ITR LCA
MonKK – OBD0 injectors dpetro1 – IACV boo5tedteg94 - OBD1 injector platinumg2 – B heat shield
EFin' Kyle – CRX R1 coilover Thegoatc – harness plugs Littlekeel – OBD1 engine harness 91(si)hatchey – ECU plugs
Gsrswapdcivic – VSS eggsi619 – B heat shield dubs97integ - Si Harness Spunkster - DA 1/2 Shaft XxDrUnKnMuNkxX - OBD1 IACV sillyboi - B-series post mount bracket thresher – OBD0 IACV k2kyl - VSS mRek9R - injectors b18vtecboi – rotors llslick - injectors Cambocheen! – torque mount 91redrex - VOLKS rim Budget Racer - IACV choptopprelude - refunded money screen_name - 97 Toyota Camry MOE@Hyper16Valve - Si hubcap k20 kid – IR Sockets zoopreme – DVD Player llicea05 WRX EXEDY Clutch ibevila – Stock Motor Mounts HRC51 - VSS ecosol - VTEC harness kevinthefawker - axles
defythemall1 - D16Y7 TB [eg6] - exhaust manifold dc5itracer - thermo housing rugimpy - Gameboy godluvstegs - Crank Sensor dc5itracer - Thermo Housing Mashi2Choco - EK NRG Hub suzieffbaby - Oil Pan & NRG QR heho - Radiator kn0tz Intake arm [eg6] - Exhaust Manifold
BOUGHT from:
88crxsir – CRX door skirt bluebird – D15 Vtec Nerologic – Many things Mr_CRX – Many things
Outsane – CRX corner light, door panel LoSt is BlaCk D15 Timing cover 24TEN – Si Seats
DC2SIR-G – GSR transmission Alanicious – linkage, RSR exhaust Trimugenhatch – B16 long block Del Sol SiR – USDM P30 ECU
Oinojo – B16 swap mccoy1178 – P30 IM Your Name – BBK TB SlowSOHC-T – NGK wire
1990CRXSIJDMEF8 – Craftsman tool box eg2jr – CRX B pipe grip200kg – TSW fourthgenhatchB17 – Bunch of SOHC
iownahatchback – D16Z6 Intake Manifold JDM_JNKY – B16 cams f@sth@tch89 - P28 ECU em1loc – P61 ECU
mabbiker – Speaker plate + AEM silentdaredevil2 – OBDI harness skavenger*ef9 – CRX head light + H&R spring w/ strut
Ldo – CRX T-bar & ½ shaft frank_el_tanke – JDM wire harness + B16 IM #1DA2HATE – B-series TB
snowboardgeek1 – EX cluster + spoon mirror ThatGreenGsr – 92-93 GSR CAMs Radim – HKS short ram
LS94tegra – D16Z6 Dizzy da9leo – DA Cat WICKED.OSS - MOMO virdizzeripsta - Seafoam .Manny. - eibach B2FiNiTY - Muteki notoRious1 - used tire 3rdgenLS – Racing shoes 424racer – CRX Distributor kaduku_ - Steelies thresher - Mishimoto hose hybrid89 - CRX Center Garnish jdm ek o - B16 TB & **** Stunna MIKE - D16A6 IM truongmai8d - Light Crank Pulley PYITR01 - ITR Harness volcomstoned - Test Pipe JDMH22HATCH - Honda MTF Ed7touge - PW Intake 90goldhatch - JG Cams Innes - Revo Camber Kit Back2JDM - CTR Harness rugimpy EG Clock TranceAddicts - D16Y8 IM hybrid89 - CRX Garnish SpeedFactoryRacing - Battery Stunna MIKE - D16A6 IM truongmai8d - Crank Pulley PYITR01 - Harness jdm ek o - Shift ****
Old Aug 29, 2009 | 12:18 PM
FOMULA91's Avatar
Default Re: Random Parts (B-series & D-series)
bump
Old Aug 29, 2009 | 01:35 PM
b20steveo's Avatar
how much for a speed sensor
Old Aug 30, 2009 | 04:13 PM
FOMULA91's Avatar
The price is up but i don't have any 98 VSS. The one I have are the 92-95 Automatic VSS... Not sure if they will fit...
Old Sep 1, 2009 | 12:47 PM
FOMULA91's Avatar
cuz the Internet is down at my new place....
Old Sep 1, 2009 | 07:06 PM
FOMULA91's Avatar
bump.... Sold some stuff....
Old Sep 3, 2009 | 10:24 AM
FOMULA91's Avatar
(-_-)
Old Sep 4, 2009 | 04:10 PM
FOMULA91's Avatar
CRX Si manifold SOLD...
Old Sep 6, 2009 | 08:52 AM
VDM_DC2's Avatar
cool you got more idle air valves ... i think i got one off of you before. haha bump
Old Sep 6, 2009 | 01:14 PM
FOMULA91's Avatar
thanks for the bump
Old Sep 6, 2009 | 08:50 PM
FOMULA91's Avatar
Sold the last set of OBD1 injectors....
Old Sep 7, 2009 | 08:06 PM
dubs97integ's Avatar
PM'ed you!
Old Sep 7, 2009 | 08:31 PM
FOMULA91's Avatar
Originally Posted by dubs97integ
PM'ed you!
PM back...
Old Sep 9, 2009 | 04:06 PM
FOMULA91's Avatar
Old Sep 10, 2009 | 05:49 PM
FOMULA91's Avatar
Old Sep 10, 2009 | 09:52 PM
FOMULA91's Avatar
Si harness SOLD...
Old Sep 13, 2009 | 08:31 PM
FOMULA91's Avatar
DC header is back in SD...
Old Sep 16, 2009 | 12:54 PM
FOMULA91's Avatar
ttt...
Old Sep 16, 2009 | 10:07 PM
FOMULA91's Avatar
OBD1 IACV SOLD...
Old Sep 17, 2009 | 03:54 PM
Junkie Si's Avatar
have you had a chance to measure the length of the test pipe? is it 2.5" inlet or 2" inlet?
Old Sep 20, 2009 | 07:55 PM
FOMULA91's Avatar
Sorry Sold it locally and I never had a chance to measure it cuz I don't have an ruler...
test pipe and resonator SOLD...
Old Sep 21, 2009 | 06:45 PM
FOMULA91's Avatar
Old Sep 21, 2009 | 07:12 PM
sillyboi's Avatar
I'm interested in the DC driver side motor mount bracket..
Old Sep 21, 2009 | 08:29 PM
FOMULA91's Avatar
PM back...
Old Sep 25, 2009 | 01:37 AM
FOMULA91's Avatar
post mount bracket SOLD...
