FS: bseries log turbo mani + DP
got a cast log style t3/t4 b series turbo mani BY VECCO which is pretty much t-netics cuz they make them to their specs as t netics no longer has off the shelf b series kits, now they are more into the newer stuff, made superb power but wasnt enough will be good for anyone wanting a street setup under 400 whp, allows to keep power steering and AC on all b series, the wastegate is mounted dead center off all 4 cylinders which allows for excellent response from the wastegate, the TIAL wastegate in the pictures on the manifold DOES NOT COME WITH IT. also i have a M1 2.5" 5 bolt down pipe stainless steel with flex pipe, the flex part of the downpipe has been bottomed out over speed bumps but has absolutely no affect on the pipe nor does it leak, deletes the converter and has a 3 bolt flange on it. has 2 o2 sensor bungs for stock and a wideband, i could not get the stock 02 out didn't even budge, o2 in working condition and is an OEM aura sensor with roughtly 30k on it, so that comes with the down pipe if you need a plug for the other bung you can get an oil drain plug m18x1.5 at advance auto for 2 bux, it is a driver side exit downpipe that allows you to keep your ac. i will clean the dp up really well once its sold and ready for shipment i did have a small leak from the pan that stain the pipe black but it comes off easy with some cleaning chemicals.
$150 obo for both willing to sell seperately tho, sensor in DP about 90 by itself, and thats oftermarket bocsh, this is oem acura, let me know. and please make offers need this stuff gone
Project_EK
Northeast (Sales)
Jun 24, 2016 03:48 AM
SOHCejcivic
Jan 5, 2009 01:45 PM
self_made
Dec 18, 2006 07:06 PM
