wtf!!!!!! loose timing belt....HELP!!
Old Aug 28, 2009 | 12:33 PM
bLu92bUbbLe's Avatar
Default wtf!!!!!! loose timing belt....HELP!!
when i put it on...it was nice and tight....but once i started the car it got loose and flabby....can this be the reason from 1-3k rpms the **** feels like it doesnt wanna go anywhere...then it picks up like a beast after that
Old Aug 28, 2009 | 12:39 PM
Former User's Avatar
Default Re: wtf!!!!!! loose timing belt....HELP!!
Did you properly tension the belt? The crank should only be turned counterclockwise.
Old Aug 28, 2009 | 12:52 PM
damn...it shud only be turned counter even wen the belt is off?...i turned it clockwise to get the bottom marks lined up....
Old Aug 28, 2009 | 12:58 PM
That should be fine. Once the belt is on, turn only counterclockwise.
Old Aug 28, 2009 | 01:02 PM
ok thanks...goin back out to do this AGAIN....
Old Aug 29, 2009 | 07:43 AM
bump....
Old Aug 29, 2009 | 08:39 AM
i got it....but she is still loosing power from 1-3k
Old Aug 29, 2009 | 09:02 AM
Frozen E's Avatar
H-T White Ops
You've got other issues.
Actually, 1-3K......it's a Honda engine. There is no power in that RPM range.
Old Aug 29, 2009 | 09:06 AM
sde780's Avatar
your timing is off
Old Aug 29, 2009 | 09:14 AM
Originally Posted by sde780
your timing is off
Yep, start by checking the ignition timing. If you can't time the engine by turning the distributor, then the mechanical timing is probably off.
Ef4doorwagon
17
Aug 30, 2014 11:58 PM
ECStarr
Honda Civic (2001 - 2005)
Aug 30, 2012 04:44 AM
dadrought6
Feb 18, 2009 05:22 AM
sidewayz32
18
Oct 25, 2005 04:06 PM
