Suspension & Brakes Theory, alignment, spring rates....
questions about trailing arm bushings
Old Aug 27, 2009 | 08:33 PM
koher_calibest's Avatar
Default questions about trailing arm bushings
hey im going to do a rear disk conversion on my ride but with the trailing arm bushings are shot i don't know if i should go oem on it or go with the energy polyurethane bushings?
Old Aug 27, 2009 | 08:36 PM
kaiba's Avatar
Default Re: questions about trailing arm bushings
OEM. You don't need a special tool to remove the bushing. Hammer is your friend.
Old Aug 27, 2009 | 08:38 PM
racebum's Avatar
judgement call. the energy bushings are easier to install and do not to be clocked properly. either way is better than what you have
Old Sep 8, 2009 | 05:07 PM
civichb98's Avatar
I re-did mine and bought the OEM ones. Plus, I used a tool to push them out and to install them. I didn't use a hammer, and the Energy Bushings are ok from what I've heard.
Just go with the OEM or the Mugans ones.
This is the tool you need though
BlackCivicEX
Suspension & Brakes
29
Jan 24, 2012 10:27 AM
Akavietboy201
Nov 21, 2009 10:48 AM
Chef Andre
Suspension & Brakes
26
Dec 21, 2008 11:38 PM
beanbag
Sep 14, 2007 09:10 AM
Dartanian
Aug 1, 2007 07:45 PM
