DA jdm Climate Control
I really don't know, I have never seen them before until these. Hell, I did not even know they existed. I guess as much or more than the ef ones. Thats why I put them on Ebay, they will sell for what they are worth.
good luck getting that to work in an USDM car. The USDM uses a slider control w/ a cable to control the temperature, whereas that uses servos and such to control the temperature (or some other electronic devices). I'm sure it requires more than just sticking the controls in the dash and wiring it up.
You are saying that the Usdm and Jdm dash are different. I just wanted to verify, I got a friend with a DA, I will check tonight. Anybody have a JDM factory manual out there??????
yeah, that wouldnt fit in the dash of a USDM integra. The driver sits on the opposite side and the climate controls are flipped as a result.
It works, I've seen it done in person. You have to cut to make it fit though. I'm also not sure if all the features were working though. My buddy had to find wiring diagrams from Japan and then translate them. He also used climate sensors from USDM Acura's. It definately involves too much work for the novice. I'll see if I can get him to post the specifics as to what exactly is involved.
HondaF1, thanks for the info. If you can get him to post the specifics that would be amazing. If not please ask him to email them too me. Thanks a lot man
Jason
Jason
looks very similar in basic design to the digital climate controls in my 89 legend LS....im sure you could use some of the same wiring and sensors from the legend which would be MUCH easier to find.
