No spark, OBD0 B16 in EF CRX
Old Aug 27, 2009 | 04:50 PM
kanebmotorsport's Avatar
Default No spark, OBD0 B16 in EF CRX
I have no spark at the plugs in my B16; it is the only thing keeping the car from running.
Tracing back, the wires are Magnecor 7.5, then the distributor is a brand-new-off-the-shelf-on-Tuesday Distributor King unit, then it is wired up to my PW3 ECU. It is an OBD0 motor in a '91 CRX.
There are no ECU codes. What can prevent the distributor from giving me spark?
Old Aug 27, 2009 | 06:59 PM
Default Re: No spark, OBD0 B16 in EF CRX
The car was initially a DPFI DX; then I converted to MPFI successfully, then the ZC blew up, then I put in the B16 and added VTEC.
Old Aug 28, 2009 | 12:27 AM
jenifertom90's Avatar
you dont have an ECU codes....i dont think that you will have to face any problem of such kind..try once again...
Old Aug 28, 2009 | 04:06 AM
Retried, still no spark at all.
Old Aug 28, 2009 | 06:59 AM
dephtone's Avatar
Are you getting spark at the dizzy? Have you opened the distributor to see if the rotor has not come loose or not present.
I would also check if you have any main relay as this gives power to the distributor as well as other various things. Also check fuse #14 under the dash, this runs dizzy power too if I recall correctly.
Old Aug 31, 2009 | 05:44 PM
Main relay was new last year.
Fuses 2 and 14 are both 10A and both fine.
Swapped the two white wires in the distributor plug, no change.
Old Aug 31, 2009 | 07:04 PM
ugpcrx's Avatar
dude i got a dist. from distributor king and it did the same thing to me!! no spark. i could not figure it out for the life of me. so i took it to a shop and they couldnt figure it out either so they bought a new dist. from one of their connections and it started but it was backfiring out the wazoo. so then i replaced my ecu and vua la. perfect first start no problems..
just my experience with distributor king...
nonvtec92
Aug 26, 2010 01:46 PM
The Dirty EJ1
15
Apr 15, 2008 06:49 AM
brokenojoke
Mar 20, 2006 02:43 PM
silent-chris
Dec 17, 2004 01:13 PM
ejprimo
Apr 25, 2003 10:20 AM
