ECU help
Old Aug 27, 2009 | 04:49 PM
_GUS_'s Avatar
Default ECU help
I am in the process of sourcing a replacement ECU for my 1991 crx dx 5spd. I am having trouble getting a straight answer about the interchange. My current ecu number is 37820 pm5 a30. Will any ecu for 90-91 civics with the "pm5" ecu work? Does the last 3 charactors really mean anything besause the revision of that particular ecu? Does it matter if it is an automatice or manaul tranny ecu?
Old Aug 28, 2009 | 07:48 AM
jlicrx's Avatar
Default Re: ECU help
the last three characters do mean something - ECUs with A## were for everything except cars originally sold in Calif - Calif cars have L## - the numbers can indicate whether it is manual or automatic - running the automatic ECU in the manual car will trigger a Check Engine Light with a code 19 for the lock-up control solenoid valve on the automatic transmission
Old Aug 28, 2009 | 04:11 PM
_GUS_'s Avatar
thank you, so my numbers must match
MeIngGM
Apr 10, 2019 07:42 AM
ramonjones16
Jul 27, 2009 12:13 AM
tiresmoke
Feb 26, 2004 10:24 PM
