coolant temperature sensor cause the car not to start?/
Old Aug 27, 2009 | 11:47 AM
aznjay510's Avatar
Default coolant temperature sensor cause the car not to start?/
the car sometimes takes a while to start, everything turns over. new battery,alt,starter,fuel pump. went to my friends house to get it scanned and it said the coolant temp sensor. would that really be the problem? and should i replace the thermostat also? thanks
Old Aug 27, 2009 | 12:23 PM
follie gatts's Avatar
Default Re: coolant temperature sensor cause the car not to start?/
sounds like you have two issues.
Old Aug 27, 2009 | 02:48 PM
aznjay510's Avatar
and what are those issues?
Old Aug 29, 2009 | 12:18 PM
darkside0770's Avatar
If the coolant temp sensor is giving the ecu a false reading then it will give you a hard or no start since the ecu is not getting the correct coolant temp
JSPECHB
Nov 14, 2014 09:30 AM
crxr82
Dec 29, 2008 09:27 AM
stocker2shocker91
Jan 17, 2007 08:54 PM
rc90hatch
Dec 19, 2005 04:01 AM
swartz
Mar 8, 2005 07:36 PM
