How do you reduce engine heat?
Old Aug 26, 2002 | 01:44 PM
CC2's Avatar
CC2
Default How do you reduce engine heat?
I heard if you turn up the heat in the cabin it will reduce the hot air in the engine bay. Is this true?
Old Aug 26, 2002 | 01:46 PM
Brandon's Avatar
Life is Suffering
Default Re: How do you reduce engine heat? (CC2)
Yes.
Old Aug 26, 2002 | 05:59 PM
Nick H's Avatar
New User
Default Re: How do you reduce engine heat? (F22turbo)
yes it is, you can also get header wrap for your header and you can put a heatshield over your intake to draw in cooler air (but this will make your engine run hotter due to the larger volume of air)....
integra1884
Apr 10, 2003 08:48 PM
integra1884
Apr 10, 2003 02:54 PM
H23A1LUDE
Aug 8, 2002 08:58 AM
NONKonformyst
May 16, 2002 07:05 AM
