the Main Relay and what it look like?
Old Aug 27, 2009 | 09:50 AM
attica's Avatar
Default the Main Relay and what it look like?
here is some info i found that helped me a lot and if your fuel pump is not working check this out.
http://www.tegger.com/hondafaq/mainrelay.html
for the main relay
Old Aug 29, 2009 | 10:32 AM
felsesser's Avatar
New User
Default Re: the Main Relay and what it look like?
This is a plastic rectangular black or grey box about 2" x 1.5" x 1.25". On a 2000 Accord push the drivers seat all the way back. Lay on your back looking under the steering column.
My attached pics are excellent. The plastic unit is mounted on a bracket. It does not come off without removing the bracket. The bracket is attached with a 10mm screw head. Use that socket with a shorty extention to break it loose, then undue - remember exactly how this was attached. Regardless, this is a major difficult job. You can only get one arm-hand in there at a time. Putting it back in is harder than taking it off.
The bracket has a tab and a screw, so putting it back, the tab must be its hole and the screw threads aligned with its hole and then put in the screw. Very hard with one hand.
I did this all without removing any panels. I did have to disconnect the brake light switch and remove the wire cluster connected to the same bracket to fit a socket in there.
Going through this trouble I did not want to chance another repair and replaced it with a new one. Old one Siemens, new one Mitsuba. Part cost 40.78.
Only time will tell as this is an intermittent no turn-over issue.
Old Aug 29, 2009 | 03:05 PM
attica's Avatar
haha mine was in behind my coin tray....way to go honda..???
brians356
26
Jul 3, 2015 10:04 PM
podom
Sep 10, 2014 11:06 PM
xTimmyx
Sep 1, 2008 12:32 PM
91sihatch
Jul 28, 2007 05:24 PM
dtrtw
Apr 5, 2005 08:54 PM
