f22b2 intake?
What seems to be the best intake setup out there for these? Or is the oem setup just as good as any $300 intake?
Also if i decide to swap on the vtec head down the road would the same intake bolt right up?
There are no aftermarket manifolds for the F22B1 & 2 series heads. I think there are is a thread on this site where someone made adaptor plate to fit an H23 manifold. I think teh F23 is another one that is close to fitting???? (not 100%)
To answer your second question, Yes. Any manifold that you make/fabricate to fit the B2 Non VTEC head will fit the B1 VTEC head.
Any $20, 3" diameter, aluminum pipe bent to fit the 94-97 Accord Chassis will work. If you buy a $20-$30 intake pipe, make sure you throw out the cheap filter and get a good quality filter. (K&N)
If you need carb legal parts In my opinion the OEM intake is better than having to pay $300 for a $20 part with a $280 CARB sticker on it.
And yes a B2 intake tube will fit a F22B1 throttle body.
egrichie
Dec 5, 2015 07:32 PM
