cel light.
Old Aug 27, 2009 | 12:04 AM
karrar55's Avatar
Default cel light.
im trying to find out the code for the cel. its 4 long flashes, one very long flash then 7 fast flashes. can someone please tell what it is? i tried going to the code thread but it didnt have my code or probably im not reading it right. help would be appreciated. thanks!!!
Old Aug 27, 2009 | 02:00 AM
GhostAccord's Avatar
Default Re: cel light.
What make, model & year is your car? & What light is it that is flashing CEL SRS or D4?
There are only long and short flashes for the check engine light. So I am going to assume that you are not reading the flash codes correctly. Where there any pauses between any of the flashes?
You may very well have a code 4 followed by a code 17 but without seeing the CEL flashes I am just guessing from what you have posted.
Old Aug 28, 2009 | 10:46 PM
notAdiesel's Avatar
could it be 57? like for an evap code
i have obd2 so i'm not too familiar with it
Old Aug 28, 2009 | 11:16 PM
karrar55's Avatar
probably is....whats a evap code????
Old Aug 29, 2009 | 04:52 AM
From my lists code 92 is the EVAP emissions code for OBD1 MIL indication (CEL flashes) I have not run across a code 57 in Honda OBD1 code lists.
notAdiesel where did you see this code listing? Can you post a link where you found it?
Here is one of the lists that I have on my Palm. If there is a Honda OBD1 code 57 I would like to add it to my list.
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evap emission control system
97teg415
Jun 1, 2008 07:03 PM
team 15
Jul 1, 2007 06:57 PM
emanLS
Oct 20, 2003 01:15 PM
GeeSeeR
Aug 10, 2001 03:39 PM
