90' Civic
Old Aug 26, 2002 | 01:13 PM
Alfa95's Avatar
Default 90' Civic
Hello everyone,
can anyone give me the specs for a 90' Civic LX sedan?
All I know so far is
1.5 Liter L4
Automatic
D15A2
Thanks
[Modified by Alfa95, 5:15 PM 8/26/2002]
Old Aug 26, 2002 | 01:41 PM
Loco Honkey's Avatar
Default Re: 90' Civic (Alfa95)
Drivetrain
Type
Transverse Inline-4, Aluminum Block and Head, Front Wheel Drive (AWD offered on wagon)
Throttle Body injection (1.6L engines have PFI)
Valvetrain
Sohc 4 valve/cyl.
Displacement
97 cu in./1590cc (Si, AWD Wagon)
91.1 cu in/1493cc (STD, DX, LX, Wagon)
Bore x Stroke
2.95 x 3.54 in./75.0 x 90.0 mm (Si)
2.95 x 3.33 in./75.0 x 84.5 mm (STD, DX, LX)
Compression Ratio
9.6:1 (88-89 CRX HF)
9.1:1 (Si)
9.2:1 (STD, DX, LX)
Transmissions
4spd manual: base 3dr
5spd manual or 4spd auto: DX/LX/2WD wagon/Si
6spd manual or 4spd auto: 4WD wagon
Horsepower (SAE)
62hp@4500 (88-89 CRX HF)
70hp@5500 (base 3dr)
92hp@6000 31/35mpg 5spd (DX/LX 3dr/4dr, 2WD wagon)
108hp@6000 28/32mpg 5spd (Si 3dr, EX 4dr, 4WD wagon)
Torque
83lbs/ft@3000 (base 3dr)
89@4500 (DX/LX 3dr/4dr, 2WD wagon)
100@5000 (Si 3dr, EX 4dr, 4WD wagon)
Fuel Economy
33/37 mpg (STD 3-door with 4 speed manual transmission)
31/35 mpg (DX/LX 3dr/4dr, 2WD wagon with 5 speed manual)
28/32 mpg (Si, EX, 4WD wagon)
Fuel
Unleaded, 86 pump oct.
Chassis & Body
Layout
Front engine/front wheel drive
Body/Frame
Unit Steel
Dimensions (3-Door/ 4-Door/ Wagon)
Wheelbase (in): 98.4 (all)
Length (in): 157.1 / 168.8 / 161.7
Width (in): 66.3 / 66.7 / 66.1
Height (in): 52.5 / 53.5 / 56.1
Curb Weight (lbs): 2127 / 2262 / 2335 (2628 4WD)
Brakes
Front
9.5 inch disc
Rear
7.1x1.0 inch drums
Assist type
vacuum
Wheels
Pressed steel, 14 x 5J (EX)
Pressed steel, 13 x 5 (DX, LX, STD)
Tires
P185/60R-14 82H (EX Coupe, Si)
P175/65R-14 (EX Sedan)
P175/70R-13 (DX, LX)
P165/70R-13 (STD) (???)
P175/70R-14 (Wagon)
Steering
Rack & Pinion
Power Assist (LX, DX Sedan or Si Hatchback w/ Auto transmission) Manual (Si, DX Hatchback or Sedan w/Manual transmission, STD)
Suspension
Front
Upper A-arms, lower L-arms, coil springs, tube shocks
Rear
Trailing arms on upper & lower lateral links, compensating links, coil springs, tube shocks
Acceleration (Si)
0-30 mph
3.0 secs
0-40 mph
4.4 secs
0-50 mph
5.9 secs
0-60 mph
7.6 secs
0-70 mph
10.3 secs
0-80 mph
13.1 secs
0-90 mph
16.5 secs
0-100 ft
22.1 secs
0-1320 ft (1/4 mile)
16.4 secs @ 84 mph
Standard Equipment
1.5L TBI 16 valve 70hp, 4spd manual, door mounted seat belts, 50/50 split rear seats, remote fuel and hatch release, rear defogger, 165/70R13 tires
DX adds: 1.5L TBI 16 valve 92hp, 5spd manual or 4spd auto, power steering w/auto tranny, motorized front belts (4dr), rear wiper/washer (3dr), tilt wheel, cargo cover (3dr), interval wipers, 175/70R14 tires
Si adds: 1.6L PFI 16 valve 108hp, dual manual mirrors, power moonroof, clock, tach, sport seats, 185/60R14 tires
LX adds to DX 4dr: power mirrors, pw, pdl, cruise, clock, tach
EX adds: 1.6L PFI 108hp, upgraded interior trim, 175/65HR14 tires
2WD wagon: DX equip plus clock, tach
4WD wagon adds: 1.6L PFI 108hp, 6spd manual or 4spd auto, full-time 4WD
Old Aug 26, 2002 | 02:25 PM
slowman's Avatar
I took way too long
Default Re: 90' Civic (F=WT)
w w thats alot of info
Old Aug 26, 2002 | 05:31 PM
Alfa95's Avatar
Thanks ALOT bro.
Thank you.
coffin on wheels
Jan 1, 2007 01:15 PM
Nisif
Jul 13, 2005 08:28 AM
OreoEF8
Apr 2, 2004 10:01 AM
i1la5sc12x
Aug 30, 2001 10:53 AM
