B18B head swap!!!
I was at a local junk yard this morning and I found a b18b head in good condition, I was wondering if I could swap this in my b18a?? I dont expect any big power gains....but stuff to cosider is: The head has less milleage than my b18a, I can benefit from the intake cam and the intake manifold differences and somebody told me I can still run obd0...is this true?? or can I just convert it to obd1 with just the head swap and the right ecu?? Also I will try to install a 96 type r oil pump in the b18a, has anyone ran into any issues when doing these??
Instead of swapping the head and having to deal with a new head gasket and head studs, just buy a $160 Blox Type R replica manifold for your LS, and change cams to your head from the B1.
Don't expect huge gains, you probably won't even feel it.
The difference in oil pumps is a small washer that ups the oil pressure. After 1996, all LS/GS/RS/SE/GSR/ITR oil pumps are the same.
Notice part #12, the little washer. The 95 and older models had that for less oil pressure in the B18-non vtec motors. After 1996, ALL Integra models had the "Type R" (they're all the same) oil pumps.
Endyn sells modified oil pumps.. they're ported and shimmed.
