Rear disk HELP
Wats goin on I was planning to put the gsr rear disks I recently bought tho I had a questions it came with the whole trailing arm slotted drilled rotors steal braided lines and the e brake cables my question being how does the trailing arm fit and the e brake cables look way to long bc my stock cables go from the handle which is a single cable thru the floor to where it connect to 2 with a spring in the middle which it then goes to both drums but the cables i havw are look alot longer then the ones that are stock I hope you can make out what I mean I'll try and get pictures up tom please and ty in advance btw it's 93 del sol ty
check the how to section for rear disc conversions. but once you take out your rear drum set up you will see how the rear disc setup goes in.
The integra e-brake cables are different from del sol cables....
When I did my rear brake conversion I used trailing arms from a 94 del sol and seen first hand that the del sol e-brake cables are much different from civic and integra cables.You need cables from a 93-97 del sol with rear disk brakes.
424racer
15
Apr 25, 2010 07:48 PM
Eg2707
Dec 21, 2006 12:45 PM
AzntaggeR
12
Aug 6, 2005 04:04 PM
fc3srx729
Jul 3, 2003 07:31 AM
