horn/hazard/srs lights won't work
Old Aug 26, 2009 | 05:42 PM
escowop's Avatar
Icon3 horn/hazard/srs lights won't work
hey everyone, i tried searching on here but i can not find any topics that match my question. horn/hazard/srs lights will not work. i have checked the connections on all of my harnesses and checked all of the fuses (using the fuse diagrams i found on this site) and everything seems to be in order. my car was stolen and recovered, and when i got it back i had to replace the ignition because they punched it. i got the ignition off of ebay from canada, and the harness plugged right in like the old one. my question is, do you think the harness from canada could be causing the problem? i am thinking one of the fuses not used in the US models might need to be used since it's from canada. what's weird is that the alarm i now have in there now is set with the horn, and when i arm/disarm the alarm, the horn still beeps. any ideas or suggestions? anything you guys can offer would be greatly appreciated. thank you.
Old Aug 26, 2009 | 06:06 PM
Former User's Avatar
Default Re: horn/hazard/srs lights won't work
What year?
Old Aug 26, 2009 | 06:08 PM
escowop's Avatar
oh, sorry. its a 1992 honda civic hatchbacl dx.
Old Aug 27, 2009 | 08:01 PM
escowop's Avatar
no love?
Old Aug 27, 2009 | 08:48 PM
Do the turn signals work?
Has the steering wheel been replaced or altered?
Double check fuses 42 (20A) and 43 (10A) under the hood.
Is the cluster SRS light bulb burned out or missing?
Old Sep 3, 2009 | 05:01 PM
escowop's Avatar
the turn signals do work. i have replaced the airbag and switched out the steering wheel recently. i think there is a bad connection somewhere. the horn honks when the steering wheel is turned to a certain angle.
Old Sep 3, 2009 | 05:18 PM
Did you check the fuses?
The SRS light and horn problem are almost surely related to the steering wheel/airbag work. You need to remove the steering wheel again to inspect.
You might check the hazard switch.
00ekcoupe
Audio / Security / Video
Nov 7, 2008 07:41 AM
g0tsilkk
Mar 25, 2006 08:44 AM
JDubya
Jul 17, 2004 08:10 PM
EJK
Aug 7, 2001 06:19 AM
