Blox B-Series VTEC High Compression Valve Set
Old Aug 26, 2009 | 04:25 PM
djteggy99's Avatar
Default Blox B-Series VTEC High Compression Valve Set
hey so im fixing to rebuild my head soon and i was looking into the blox valve set intake and exhaust i was just wondering would these fit in without any head work done to it. Would they just place in like the oem ones?
Old Aug 26, 2009 | 05:17 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Blox B-Series VTEC High Compression Valve Set
If you want to do this right you would get a valve job. If you just want to half *** it then you maybe could get away with just lapping in the valves. If you want to just "slap it together" then you could do what you described and start burning candles.
Old Aug 26, 2009 | 05:20 PM
djteggy99's Avatar
any suggestions on after market valves that will fit in like oem ones dont omni make some? Ive looked into oem valves and there expensive.
Old Aug 26, 2009 | 05:29 PM
djteggy99's Avatar
i was just wondering cause in the descriptions they dont say anything about oversize or oem size and if it was required wouldnt they tell us it needs modification to the head?
mar778c's Avatar
Community Builder
No off the shelf valve will fix correctly. They are cut to match the valve seats (ie valve job). a simple valve job is about 300.
Old Aug 26, 2009 | 05:32 PM
mar778c's Avatar
Community Builder
No, it is common knowledge that when you will replace the valves you get a valve job.
Do you have a Helms manual?
Old Aug 26, 2009 | 05:34 PM
djteggy99's Avatar
okay thanks dude i guess i will just go with oem ones since i dont wanna do any headwork....
Old Aug 26, 2009 | 05:42 PM
mar778c's Avatar
Community Builder
LOL, why are you replacing the valves in the 1st place?
What you are attempting to do is waste money. Without a valve job, I guess I don't understand the purpose.
Old Aug 26, 2009 | 05:45 PM
djteggy99's Avatar
replacing cause one exhaust valve broke and seems too be a leak so i decide to replace all of them.
Old Aug 26, 2009 | 06:04 PM
mar778c's Avatar
Community Builder
You definitely need a valve job. Don't mess around.
Old Aug 26, 2009 | 06:35 PM
djteggy99's Avatar
imma take my head to get it shaved and cleaned thats about it nothing else major
Old Aug 26, 2009 | 06:40 PM
00Red_SiR's Avatar
All Motor Mentor
that's all well and good but if you replace valves without a valvejob, just send your money to me and throw your head away. That's about all the good it will do.
Old Aug 26, 2009 | 06:54 PM
djteggy99's Avatar
so even with oem valves i would still need a valve job?
Old Aug 26, 2009 | 07:04 PM
Scott_Tucker's Avatar
Yes, definitely.
Old Aug 26, 2009 | 07:55 PM
djteggy99's Avatar
will after i replaced my two exhaust valves in cylinder 1 i compression checked it and it came out 220 and motor is running strong and no valvejob.
Old Aug 26, 2009 | 08:03 PM
mar778c's Avatar
Community Builder
^^^LOL, I guess that proves your point.
Maybe you should try a leakdown test.
Old Aug 26, 2009 | 08:11 PM
Fkned's Avatar
It isn't always nesasary to get a vj but it is recommended to at least get them checked to see if they seal. It's like putting a used head on a motor it may seal or not but you should get the deck checked at a minimum so you don't waste time and money doing it twice.
You got lucky this time around be gratefull not condesending because we told you how to do it right and you ignored it and were luckily rewarded.
If I were you I wouldn't waste your cash on the lottery friday your luck for the has been used up,lol.
Old Aug 27, 2009 | 02:23 PM
djteggy99's Avatar
no valvejob or valvejob i just wanted to know if the blox valves would drop in like the oem ones?
Old Aug 27, 2009 | 02:33 PM
92cxturbo's Avatar
If by drop in you mean will they fit, then yes. After you do that without a valve job let us know what your leakdown test looks like so we can say I told you so...
Old Aug 27, 2009 | 05:01 PM
Even though your valves seal now, you don't know how long they will seal. It may last 100k miles or they may leak in a month. That is why I would have ground the seats.
Old Aug 28, 2009 | 09:53 AM
00MRSi's Avatar
It's amazing, people come on here asking for advice and they just ignore it. Why even ask?
Old Aug 28, 2009 | 11:11 AM
djteggy99's Avatar
haha im not ingoreing it my quesition was just will they fit like the size are they standard or bigger then oem ones. I never asked about a valvejob or anything but yeah i know i should get a valvejob but i am taking my chances.
Old Aug 28, 2009 | 07:55 PM
terqui's Avatar
Yeah and the answer was you need a valvejob to get the valves to fit you idiot.
Old Aug 28, 2009 | 08:06 PM
fastasscivic's Avatar
New User
hey i have a eg hatchback and i want to do a swap either h22 or itr which one is better.. i had a h22 in a eg hatchback before and it was fast but i want to do a eazier swap like the itr.. but will it be fast too??
Old Aug 28, 2009 | 08:11 PM
wed3k's Avatar
you gotta know the right people, i do valve jobs pretty damn cheap but thats another story for another day.
