b18c1 into 93 integra harness question
were swapping the b18c1 outta the 94 gsr into a 93 DA integra special. we have both vehicles for any parts needed, yet neither harness matches perfectly (as figured). is there an adapter of sorts to just use the gsr harness into the 93, or will i have to get out the old soldering iron and wire the vtec into the 93 harness? any info appreciated, and links for any wiring would be awesome.
8zero8 was a tremendous help im sure...
...just use the stock harness from the 93, fit it on the engine then add the additional wires you need.
also get a skunk2 or blox intake manifold to bypass the IABs
srv3fender
Jun 15, 2004 04:43 AM
