to swap or not to swap that is the question??
im getting a 91 hatch with a dohc d16 zc swap i want to do a b18 swap but idk much about swaps sum1 told me that the zc was pretty quick with a turbo and internals but ive also been told they werent nething special lmk what you think please
A b18 ls motor puts around the same power as the zc motor. if building one of them i would say the b18 would put down more. considering that there is more parts to buy and better parts than you could find for a zc motor. the swap is easy tho. ecu and jumper harness . wire up a few things and your done.
yes. easy can get that. and more. depending on your build and budget. i had a single cam mini me. made 300 on 14psi. had rods pistons and a zex 59300 cam.
yes. everything will fit that i know of. .... camshafts will not fit..... rods and pistons will.. do you have a d16a8 or is it the zc motor.
you would get them for a zc. you can go on exospeed and buy stage 1 cams and they should work fine for your setup. here is the site.
http://www.exospeed.com/category.php?id=309
BLuDoHcReX
16
Dec 23, 2002 02:45 PM
