WHAT ARE THESE RELAYS TO!!??
Old Aug 26, 2009 | 10:31 AM
kreatekustomz's Avatar
Default WHAT ARE THESE RELAYS TO!!??
Hello all, I'm currently doing an engine bay shave and wire tuck. I'm going through the harness now determining what plugs I can remove. I cant remove the whole from sub-harness that runs on the radiator support if I can just determine if I need these relays. here are a few pictures and where they was located before I removed the harness.... I know two of the relays are ABS Fail Safe and A/C Condenser Fan. but I'm still left with two unknown and cant find them in the FSM...
Old Aug 26, 2009 | 10:52 AM
bks84's Avatar
Loved
Default Re: WHAT ARE THESE RELAYS TO!!??
air conditioning and/or coolin fan relay
Old Aug 26, 2009 | 12:55 PM
cooling fan relay meaning Fan Motor? There is still 1 I dont know of..
1. ABS Fail Safe
2. AC Condenser
3. MAYBE Fan Relay?
Old Aug 26, 2009 | 01:11 PM
**birdnest**'s Avatar
[QUOTE=kreatekustomz;39757957]Hello all, I'm currently doing an engine bay shave and wire tuck. I'm going through the harness now determining what plugs I can remove. I cant remove the whole from sub-harness that runs on the radiator support if I can just determine if I need these relays. here are a few pictures and where they was located before I removed the harness.... I know two of the relays are ABS Fail Safe and A/C Condenser Fan. but I'm still left with two unknown and cant find them in the FSM...
\QUOTE]
When I did a wire tuck on my teg, those 2 relays went back to the abs plugs and I deleted my abs, the other two are for the fans not 100% sure but I left them I just moved them.
Old Aug 26, 2009 | 01:44 PM
well thats makes sense but one of the two relays you mention as (fans) is actually to the AC Condenser. You kept the two on the driver side of the car?
Old Aug 26, 2009 | 02:33 PM
bump
Old Aug 26, 2009 | 02:58 PM
bks84's Avatar
Loved
did that harness attach to the underside of the radiator support? if it did then as i said its the AC wiring harness.
Old Aug 26, 2009 | 03:30 PM
steveharrmr23's Avatar
they are the relays for the fans the abs ones have orange plugs
Old Aug 26, 2009 | 04:44 PM
Thats what I thought! The two passanger side relays was orange and the driver side relays are brown plugs. I will just shorten those wires and remove the rest of the harness considering the other 5 plugs I dont need...You can keep an eye on my progress on my build thread...
Old Aug 26, 2009 | 04:53 PM
I kept the ac on my car so yeah. good luck on the build.
Old Aug 26, 2009 | 05:07 PM
Haha well I pulled the harness apart (the ac sub harness) and found the two relays on the right side are to the A/C components only...
Relays should be like this
Passanger side
1. ABS Pump Relay
2. ABS FAIL SAFE Relay (backs up relay number one) Plug Number C208
Driver side
3. AC Compressor Clutch Plug Number C154
4. AC Condenser Fan Motor Plug Number C155
Where does the Radiator Cooling Fan get it's signal? Back to the FSM...
Old Aug 26, 2009 | 05:14 PM
Jimmy's Avatar
Global Moderator
https://honda-tech.com/forums/acura-integra-6/i-need-help-knowing-what-2633057/
Old Aug 26, 2009 | 05:47 PM
why did you give me a link to someone asking the same question?
Old Aug 26, 2009 | 05:56 PM
Its looks like from the FSM the Radiator Cooling Fan has a relay of its own, however; the signal wire to the relay is also connected to the AC Diode (green wire.)
Correct me if i'm wrong but I beleive I can disregard the AC "sub-harness" all together,relays and all, and be ok as far as radiator cool fan goes?
Old Aug 26, 2009 | 06:29 PM
The main fan goes back to the fuse box, if you dont plan to keep the other fan you dont need the wires going to the ac stuff. hope this helps
Old Aug 26, 2009 | 08:14 PM
yeah thats what I concluded... I already removed the plug that went to the AC Harness... For anyone wondering the same thing in the future my layout a couple replies up is correct with the addition the Cooling Fan Relay is in the main fuse box.
Alan Da Silva
Jul 5, 2017 09:22 AM
Zero1Niner
Jul 27, 2016 05:02 PM
sdlong92
May 25, 2008 10:21 AM
rockcity
15
May 23, 2008 06:10 PM
keoni72
Nov 29, 2002 10:59 AM
