Best source for OEM headlights?
My headlights are alittle faded and have alittle moisture in them. What is the best source for 99-00 OEM style headlights? How much should I expect to pay?
If you are just looking for stock OEM headlights...you might want to consider just doing a little work to your current ones. You can bake the headlights and reseal them to get the moisture out and you can do a sanding/polishing process to make them look nice and clear again.
http://www.permatex.com/products/Aut...tion_Kit_1.htm
That is the best product I have ever used for headlight cleaning. I have a 98 Civic coupe and the headlights were faded and cloudy and yellowed. I followed the directions in the pack, and an hour or so later, I had brand new looking headlight. The pack cost me $15 and it saved me hundreds for new headlights. As far as the moisture, I am not sure what you can do with that, but there may be a way to go from behind with headlight and use a rag to get rid of the water droplets. Then, I would suggest to reseal the headlights and make sure it doesn't happen again.
